02-12-2019, 06:15 | #1 (permalink) |
Insane Poster Join Date: Mar 2016 Location: tecoman colima
Member: 2551465 Status: Offline Thanks Meter: 56 | Reparar Imei Certi Fail J727p Binario 4 2 buscan el puerto que genera en modo descarga 3 seleccionan en e modelo samsung gsm 4 buscan el las opciones modemstx_reset 5 le dan start gc pro resetiar las particiones del modem y asi mismo reparando el imei certi fail y al encender marcan *#0011# y veran que el imei certi quedara pass |
The Following User Says Thank You to CelularCris For This Useful Post: |
02-12-2019, 11:22 | #3 (permalink) | |
Freak Poster Join Date: Mar 2014
Member: 2148129 Status: Offline Thanks Meter: 42 | Quote:
02-12-2019, 13:49 | #4 (permalink) |
No Life Poster Join Date: Oct 2010
Member: 1422878 Status: Offline Thanks Meter: 164 | El forum es en ingles, pero ojala se dieran tan buenas soluciones como esta q esta en espaņol The forum is in English, but hopefully they gave as good solutions as this is in Spanish Repair Imei Certi Fail J727p Binary 4 1 put in download mode the j727p 2 look for the port that generates in download mode 3 select in e model samsung gsm 4 search the modemstx_reset options 5 give you start gc pro reset the modem partitions and likewise repairing the imei certi fail and on power up they dial * # 0011 # and you will see that the certi imei will remain pass |
The Following User Says Thank You to helpinterchange For This Useful Post: |
02-13-2019, 06:47 | #5 (permalink) |
Member: 2551465 Status: Offline Thanks Meter: 56 | Repair Imei Certi Fail J727p Binario 4 1.- Put in download mode the j727p 2.- Select on the samsung GSM model 3.- search modemstx_reset options 4.- they give start gcpro reset the modem partitions and likewise repairing the imei certi fail and on power up they dial * # 0011 # and you will see that the certi imei will remain pass |
02-13-2019, 12:15 | #6 (permalink) | |
Banned Join Date: Sep 2016 Location: living on the edge
Member: 2620145 Status: Offline Thanks Meter: 319 | https://www.gsmhelperteam.info/2019/...pD7qjTq6AXBY7g Quote:
02-14-2019, 14:43 | #7 (permalink) |
Freak Poster Join Date: Sep 2008 Location: jamaica
Member: 852991 Status: Offline Thanks Meter: 19 | if imei cert fail check meid and imei if match if doesn't it give imei cert fail all need to do is repair meid and you all good |
The Following User Says Thank You to thee011 For This Useful Post: |
