Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 05-31-2018, 00:19   #1 (permalink)
Member: 2382052
Thanks Meter: 1,255
Samsung g900p reactivation lock done
Using Version...1.0.0.0057
Selected Port SAMSUNG Mobile USB Modem #171 COM87
Selected Model GT-I5500
Selected Task SAMSUNG RLOCK_ADB
Searching ADB device Please wait..
Device Detected...
Security:= OFF Unsecure device
SELinux := Enforcing
model:= SM-G900P
Androids Version:= 6.0.1
Description Version:= kltespr-user 6.0.1 MMB29M G900PVPS3CQB3 release-keys
Platform:= msm8974 [ qcom ] [ MSM8974PRO ]
Baseband:= G900PVPS3CQB3
VER:= G900PVPS3CQB3/G900PSPT3CQB3/G900PVPS3CQB3/G900PVPS3CQB3
Carrier := SPR_USA
EFS CSC := SPR
Knox Warranty := Not Void
Security Patch := 01-02-2017
Simstatus:= ABSENT
ANDROID-ID = 347496e5_00006905EC
Device is Unsecure Rooted
SAMSUNG RLOCK_ADB UNLOCK STARTED...
Phone Found Wait...
Model := G900P
VER := G900PVPS3CQB3/G900PSPT3CQB3/G900PVPS3CQB3/G900PVPS3CQB3
Phone IMEI := AT+IMEITEST=1,
REACTIVATION LOCKED...
REACTIVATION DISABLE SUCCESS...
Please Reflash such phone...
!!! Success !!!!
Total Time Take...00:02:15
Log Saved
The Following 3 Users Say Thank You to maxpatri9 For This Useful Post:
Old 07-09-2018, 23:09   #2 (permalink)
Member: 1035611
where are the option elected Task SAMSUNG RLOCK_ADB ?
i see reactivation lock dont see samsung rlock adb
Old 07-10-2018, 03:48   #3 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,093
u right Selected Task SAMSUNG RLOCK_ADB
rlock adb
The Following User Says Thank You to CHANDARAKK For This Useful Post:
Old 07-15-2018, 19:49   #4 (permalink)
Crazy Poster
Member: 2274427
Thanks Meter: 10
how do you root??????????????
Old 07-19-2018, 22:07   #5 (permalink)
Member: 482218
Thanks Meter: 104
i also need root to remove rlock.
Old 07-20-2018, 09:19   #6 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 5,813
@el_venga
Hello
GCPro support have all tested eng root please use that. G900A root work on P,T ETC
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 07-20-2018, 15:17   #7 (permalink)
Member: 482218
Thanks Meter: 104
Originally Posted by stanner_austin View Post
@el_venga
Hello
i get secure check fail.
Old 07-20-2018, 20:29   #8 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 103
@el_venga
Hello
Will work on G900F? I am trying to find one but no result.
Old 07-21-2018, 12:36   #9 (permalink)
Member: 49752
Thanks Meter: 5,813
@el_venga
Hello
Are you sure your phone is P ? must work we tested when we released solution A eng root worked on P
You can downgrade bootloader to combination or stock older same rev code and check again.
At present we do not have any other solution sorry.
ps: You are doing downgrade bootloader at your own risk we are not responsible for any brick or damage to your phone.
@luisy
Hello
F is qcom then it will work for sure. unless you have same issue like secure check fail means bootloader reject such eng root downgrade bootloader may help..
Old 07-27-2018, 16:00   #10 (permalink)
Member: 2774290
Sonork: https://www.facebook.com/
tiene el root
amigo tiene el engroot por que es descargado 2 y no me funciona
Old 07-30-2018, 17:04   #11 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 103
G900A_Engroot doesn't work for G900F. I have tried without success. I rooted the phone manually using towelroot, but GCProkey doesn't delete the account.
Using Version...1.0.0.0058
Selected Port
Device Detected...
SELinux := Permissive
model:= SM-G900F
Androids Version:= 4.4.2
Description Version:= kltexx-user 4.4.2 KOT49H G900FXXU1ANCE release-keys
Baseband:= G900FXXU1ANCB
VER:= G900FXXU1ANCE/G900FXXU1ANCB/FA44_G900FXXU1ANG1
Unknown CSC
EFS CSC := CRC
Knox Warranty := Void
Simstatus:= ABSENT
IMEI-1 = 353750068100885
ANDROID-ID = 59679acc_353750068100885
type1 root exploit possible.
SU Version..2.52:SUPERSU
Device is Secure Rooted..uid=0
System Permission is Read/Write...
Fail to find security data report to support...
!!! Fail !!!!
Total Time Take...00:00:13
Old 07-30-2018, 17:06   #12 (permalink)
Member: 49752
Thanks Meter: 5,813
@luisy
Come on read some basic first in FAQ.
Old 10-01-2018, 06:50   #13 (permalink)
Member: 2763706
Thanks Meter: 55
@el_venga
Hello
i am new GC PRO user, i need few eng roots, i did not find GC PRO support..
from where, can i access gc pro support.... ..
need to have that tested eng root....please
Page generated in 0.36475 seconds with 7 queries
