Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 12-12-2017, 12:10   #1 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Question Samsung G930T bad ask
Hi, i tried it two times and both times got result from server is bad ask.
what is the issue why it's saying like that ?
Here the logs for both tries
First Try
Using Version...1.0.0.0052
Selected Model GT-I5500
Selected Task SAMSUNG ASK/RPL UNLOCK
Searching ADB device Please wait..
Device Detected...
Security:= OFF Unsecure device
SELinux := Enforcing
model:= SM-G930T
SAMSUNG ASK/RPL STARTED...
Device is Unsecure Rooted
Please Wait while...
Please wait starting task...
Send ASK Saved := 2c99493d.ask
!!! Success !!!!
Restart Phone Manually if not done auto...
Total Time Take...00:00:04
Second Try
Device Detected...
model:= SM-G930T
!!! Success !!!!
Old 12-12-2017, 12:20   #2 (permalink)
Member: 2450214
Thanks Meter: 106
First Try
Device Detected...
model:= SM-G930T
!!! Success !!!!
Second Try
Device Detected...
model:= SM-G930T
!!! Success !!!!
Selinux should be permissive i think 🤔
Root phone and try again.
Old 12-12-2017, 12:39   #3 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@amanvir
Hello
Download update60 we improved update tool for non english windows & added check for bad ask.
Old 12-12-2017, 12:41   #4 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Okay Sir....let me try and will post the result....
Old 12-13-2017, 12:09   #5 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
I tried again and this is the third time and server said "Do not resubmit again with this bad ask file"
Old 12-13-2017, 12:17   #6 (permalink)
Member: 49752
Thanks Meter: 6,085
@amanvir
Hello
Did you download update60 and use that ?
If yes contact me over skype with log and ask.
Old 12-13-2017, 13:01   #7 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Yes sir i did that, okay i will follow up you there.
Old 12-14-2017, 23:50   #8 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
I'm still waiting for your reply on skype, text you so many times but no response from your side plz help me to unlock this phone.
Old 12-15-2017, 13:18   #9 (permalink)
Member: 49752
Thanks Meter: 6,085
@amanvir
Hello
i have added you.. you still not posted update60 ask read log here.
The Following 2 Users Say Thank You to stanner_austin For This Useful Post:
Old 12-15-2017, 16:06   #10 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Thank you so much you solved my issue phone is unlocked now
Old 12-15-2017, 20:35   #11 (permalink)
Member: 2277857
Thanks Meter: 68
Was the solution upgrading to Version 60? I have the same problem on this phone.
Old 12-15-2017, 20:54   #12 (permalink)
Member: 1000658
Thanks Meter: 69
im having the same problem can you please post solution
Old 12-16-2017, 07:59   #13 (permalink)
Member: 1740779
Thanks Meter: 143
You ask for help say how hard it is to get it and when you do you don't even bother to share and try to help others.
The Following User Says Thank You to vaevictus0321 For This Useful Post:
Old 12-16-2017, 10:07   #14 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
Hello
Where is logs with same problem ?
With out logs we cant help
Old 12-16-2017, 22:32   #15 (permalink)
Member: 2277857
Thanks Meter: 68
Here is my log , shows success and creates file. Vendor says the file is bad, wrong size. I checked the .ask file and it is 1.374 kb. Please address this as vendor is not being responsive. I updated to Version 60, file size is the same.
Device Detected...
model:= SM-G930T
Send ASK Saved := c27ed763.ask
!!! Success !!!!
Page generated in 0.18518 seconds with 8 queries
