04-03-2017, 17:50 | #19 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2318226 Status: Offline Thanks Meter: 29 | DANGER i cant reinstall any firmware after install Samsung S7 (G930x QC) and S7Edge (G935x QC) Eng Boot Root for 2017 firmwares ODIN FAILL <ID:0/016> Added!! <ID:0/016> Removed!! <ID:0/016> Added!! <ID:0/016> Odin engine v(ID:3.1203).. <ID:0/016> File analysis.. <ID:0/016> SetupConnection.. <ID:0/016> Initialzation.. <ID:0/016> Get PIT for mapping.. <ID:0/016> Firmware update start.. <ID:0/016> SingleDownload. <ID:0/016> boot.img <ID:0/016> recovery.img <ID:0/016> system.img.ext4 <ID:0/016> FAIL! (Ext4) <ID:0/016> <ID:0/016> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
04-03-2017, 23:29 | #20 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
The Following User Says Thank You to CHANDARAKK For This Useful Post: |
04-05-2017, 19:38 | #22 (permalink) | |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
Enjoy https://mega.nz/#!BEshQDgS!fMLBUm5ok...RdZaLuUfq4v8Jk | |
The Following 3 Users Say Thank You to Alexandroid For This Useful Post: |
04-11-2017, 00:04 | #24 (permalink) | |
https://www.androidfilehost.com/?fid=457095661767142259 Unlock and reflash again g930p 7.0 | |
The Following User Says Thank You to Alexandroid For This Useful Post: |
04-11-2017, 00:10 | #25 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | Quote:
thanks bro but thats the matter that client dont want to wait and no have now firmware fo reflash thanks anyway | |
04-12-2017, 13:47 | #26 (permalink) | |
https://androidfilehost.com/?fid=457095661767151390 | |
05-19-2017, 14:32 | #29 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | SM-G930A works perfect and rooted but noy unlock. Root using this method: 1. Download Modified Odin and Engineering Kernel https://www.androidfilehost.com/?fid=457095661767142259 This is special Odin to bypass SHA-256 mega:#!BEshQDgS!fMLBUm5okmplWvPHBqLx...RdZaLuUfq4v8Jk 2. Flash the kernel to your phone a. Boot into download mode (Power, Volume Down, and Home button) b. Put the Kernel file into AP on Odin c. Flash, and boot phone 3. Download SuperSU made for our phone, and extract into C:\adb\super (You're going to need to create the "super" folder) https://www.androidfilehost.com/?fid=457095661767142260 4 Open a command prompt in C:\adb (Shift right-click in the folder, click "Open command window here") then navigate to the super folder: type "cd super" into the command prompt 5 Enable USB debugging on your phone, and enter the following command into the command prompt a. "Root.bat" |
The Following User Says Thank You to gcceleghg For This Useful Post: |
