12-13-2017, 22:42 | #46 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Here's a tip, don't waste your time trying to read the code or direct unlock the G930T/G935T. The lock is encrypted, thus you can only use the ASK/RPL solution. | |
12-13-2017, 23:32 | #47 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
12-14-2017, 02:03 | #52 (permalink) | |
Full root is not "perfect" but acceptable. Currently for the QC G930x there's this eng-boot-root available Samsung_G930x_UVE4BQB1_v7.0.0_QC_Eng_Boot_Root_v20 17-03-01.TAR And for the QC G935x this one gives the smoothest experience yet: Samsung_G935x_UVE4BQH7_v7.0.0_QC_Eng_Boot_Root_v20 17-08-29.TAR much better than Samsung_G935x_UCE4BQA6_v7.0.0_QC_Eng_Boot_Root_v20 17-03-01.TAR | |
The Following User Says Thank You to BillA For This Useful Post: |
12-14-2017, 03:33 | #53 (permalink) | |
12-16-2017, 14:03 | #54 (permalink) |
No Life Poster Join Date: Mar 2005 Location: HOUSTON TEXAS Age: 57
Member: 127269 Status: Offline Sonork: 100.1605945 Thanks Meter: 68 | [QUOTE=BillA;12380464]Here's the latest Samsung S7 (G930x QC) and S7Edge (G935x QC) Eng Boot Root for 2017 firmwares including Nougat, helpful for repair work. Note that these are for ALL QC - QualComm versions only! Samsung_G930x_QC_Eng_Boot_Root_v2017-03-01.TAR https://www.androidfilehost.com/?fid=457095661767142259 This file doesnt work on G930A 7 version for me ,can u provide me another link please |
12-23-2017, 06:46 | #55 (permalink) | |
Member: 92260 Status: Offline Thanks Meter: 843 | [QUOTE=RAJBHATIA;12846574] Quote:
This newer eng-boot should work with Android 7.x.x Samsung_G93x_QC_Eng_Boot_Root_v2016-04-22.ZIP https://www.androidfilehost.com/?fid=457095661767150873 | |
12-23-2017, 11:35 | #56 (permalink) | |
Member: 92260 Status: Offline Thanks Meter: 843 | Samsung Security+OTA Disabler [QUOTE=BillA;12858934] Quote:
Oops wrong link left above... Here's the correct one for the G930 QC v7.x.x Samsung_G930_QC_Eng_Boot_Root_v2017-03-01.TAR https://www.androidfilehost.com/?fid=457095661767142259 And here's a new one for the G935 QC model with much less lag than the previous version Samsung_G935_QC_Eng_Boot_Root_v2017-08-29.TAR https://www.androidfilehost.com/?fid=817906626617954238 Also, in order to avoid those annoying boot-loops, just run this script BEFORE flashing an eng-boot to disable Samsung's Security+OTA. Some commands may show an error, which is fine since this is a generic script for many different models. I'd recommend running it again immediately AFTER the eng-boot flash just to be on the safe side. Must have ADB enabled, and to undo it simply do a factory reset or flash a full stock over it. Samsung_Security+OTA_Disabler_(BillA_v2017-12-01).ZIP https://www.androidfilehost.com/?fid=673791459329068841 Unzip it and run this batch file which should be at top of the folder: _Samsung_Security+OTA_Disabler_(BillA_v2017-12-01).BAT Enjoy! | |
The Following 4 Users Say Thank You to BillA For This Useful Post: |
02-08-2018, 10:22 | #57 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2808983 Status: Offline Thanks Meter: 0 | more details please "Also, in order to avoid those annoying boot-loops, just run this script..." If you don't mind explaining a little more please: exactly how can I run this script? |
02-08-2018, 19:26 | #58 (permalink) |
Freak Poster Join Date: Feb 2015 Location: L&J_CUBA
Member: 2352896 Status: Offline Thanks Meter: 116 | It is a .BAT, it means it is an executable file in windows, jus double clic and enjoy!!! (Of course you need adb installed in your PC, else you have to run this scrip from a folder who has it.) |
