09-29-2016, 10:45 | #1 (permalink) |
Freak Poster Join Date: Feb 2014 Location: INA
Member: 2130017 Status: Offline Thanks Meter: 43 | SM-925T Write cert succes but how to write original SN? Code: Using Version...1.0.0.0038 Selected Port VCP0 = COM10 Selected Model SM-G925T Selected Task SAM CERT WRITE USB ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := AT+SW VER := AT+SWVERSION=1,0 Phone IMEI := 3577300604xxxx Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update IMEI Ok.. SKEY := 0346 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:03:44 Log Saved Code: Using Version...1.0.0.0038 Selected Model SM-G925T Selected Task SAMSUNG T-MOBILE UNLOCK Searching ADB device Please wait.. Device Detected... model:= SM-G925T Androids Version:= 6.0.1 Description Version:= zeroltetmo-user 6.0.1 MMB29K G925TUVS4EPH2 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ SHANNON333 ] Baseband:= G925TUVS4EPH2 VER:= G925TUVS4EPH2/G925TTMB4EPH2/G925TUVS4EPH2/G925TUVS4EPH2 Carrier := TMB_USA Network Mode := LTE Simstatus:= NETWORK_LOCKED ANDROID-ID = 04157df44becef11_000098834B Detected su binary at /xbin Detected su binary at /bin SU Version..2.77:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... SAMSUNG ALL T-MOBILE UNLOCKING STARTED... Checking Data... Waiting for Loader... Loader Ok... Direct Unlock Success... !!! Success !!!! |
09-29-2016, 11:40 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @izzicruise Hello This is hardware emmc base device serial can not be changed. If your talking Rxxxx then use AT+SERIALNO=2,11digitSN in at terminal and press send at |
The Following User Says Thank You to stanner_austin For This Useful Post: |
09-29-2016, 12:57 | #4 (permalink) | |
Member: 2130017 Status: Offline Thanks Meter: 43 | Quote:
adb shell shell@zeroltetmo:/ $ su su root@zeroltetmo:/ # AT+SERIALNO=2,R58G41FE93L AT+SERIALNO=2,R58G41FE93L sush: AT+SERIALNO=2,R58G41FE93L: not found not change on my phone | |
09-29-2016, 13:33 | #5 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @izzicruise Hello I have told gcpro setting tab AT TERMINAL. not adb shell. Please read full answer. |
09-29-2016, 14:31 | #6 (permalink) | |
Code: ...Port List End... Using Version...1.0.0.0038 Selected Port VCP0 = COM10 Selected Task GC AT Reply ASCII := AT+SERIALNO=2,R58G41FE93L+SERIALNO:2,OKOK Reply Hex := 41542B53455249414C4E4F3D322C523538473431464539334C0D0A0D0A2B53455249414C4E4F3A322C4F4B0D0A0D0A4F4B0D0A Total Time Take...00:00:12 | |
09-29-2016, 14:36 | #7 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @izzicruise Hello Samsung cert hold sn if u write cert gcpro will write sn from cert. You can not write any digit imei. if you want to get original imei you must get that cert or backup nv data. |
09-29-2016, 14:46 | #8 (permalink) | |
#Case close problem hasbeen solved | |
