02-07-2017, 21:46 | #1 (permalink) |
Insane Poster Join Date: Jul 2016
Member: 2598737 Status: Offline Thanks Meter: 4 | SM-G930P FRP Failed(success) Phone's firmware: G930PVPS4APK1 When i start the remove frp job, i get a success message but the problem is that nothing happens, the google lock is not removed. Why frp removal does not work on newer firmware versions ? |
02-08-2017, 15:14 | #3 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | Quote:
You supposed to let it boot then it will let you go to the home screen then go to settings then factory reset it, keep in mind that this is just a bypass you have to factory reset for permanently removing FRP.... Sent from my iPhone using Tapatalk | |
02-08-2017, 19:11 | #4 (permalink) |
Member: 2598737 Status: Offline Thanks Meter: 4 | Using Version...1.0.0.0041 Selected Port ssudmdm0001 = COM12 Selected Model SM-G930P Selected Task SAMSUNG FRP Remove Searching phone... Device Found.. MODEL=SM-G930P;UN=CE011601A903C63C03;CAPA=32;VENDOR=SAMSUNG ;FWVER=0003;PRODUCT=KLUBG4G1CE-B0B1;PROV=PASS; Init ok.. FRP Removed. !!! Success !!!! Restart Phone if not auto... Total Time Take...00:00:14 |
02-10-2017, 08:45 | #6 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @dorin1993 Hello You are using wrong FRP solution for s7 phone. Read helpfile name updatexx\helpfiles\Details help on FRP.txt for samsung 2016 phones. Insort: G930T root at support work on G930P then use frp remove adb will clear frp just need to reflash stock boot.img to get phone working fully. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
02-10-2017, 18:24 | #7 (permalink) |
Member: 2598737 Status: Offline Thanks Meter: 4 | Thanks m8. Using Version...1.0.0.0042 Selected Model SM-G930P Selected Task FRP REMOVE ADB Searching ADB device Please wait.. Device Detected... Security:= OFF Unsecure device model:= SM-G930P Androids Version:= 6.0.1 Description Version:= heroqltespr-user 6.0.1 MMB29M G930PVPS4APJ2 release-keys Platform:= msm8996 [ qcom ] [ msm ] Baseband:= G930PVPS4APJ2 VER:= G930PVPS4APJ2/G930PSPT4APJ2/G930PVPS4APJ2/G930PVPS4APJ2 Carrier := SPR_USA EFS CSC := SPR AP UART Status := Disable. Simstatus:= ABSENT ANDROID-ID = cea22aab_0000DB71B1 Device is Unsecure Rooted ANDROID FRP REMOVE ADB STARTED... !!! Success !!!! Restarted phone... Total Time Take...00:00:03 |
02-11-2017, 00:46 | #8 (permalink) |
Member: 2598737 Status: Offline Thanks Meter: 4 | Unlock also works on PJ2 versions or later but it also requires this unsecure root. It is very difficult to get it right, a very high precision is required. Using Version...1.0.0.0042 Selected Model SM-G930P Selected Task SAMSUNG SPRINT UNLOCK Searching ADB device Please wait.. Device Detected... Security:= OFF Unsecure device model:= SM-G930P Androids Version:= 6.0.1 Description Version:= heroqltespr-user 6.0.1 MMB29M G930PVPS4APJ2 release-keys Platform:= msm8996 [ qcom ] [ msm ] Baseband:= G930PVPS4APJ2 VER:= G930PVPS4APJ2/G930PSPT4APJ2/G930PVPS4APJ2/G930PVPS4APJ2 Carrier := SPR_USA EFS CSC := SPR AP UART Status := Disable. Simstatus:= ABSENT ANDROID-ID = cea22aab_000056EB2C Device is Unsecure Rooted SAMSUNG ALL SPRINT UNLOCKING STARTED... Checking Data... Waiting for Loader... Loader Ok... No device found Please make sure DIAG PORT is selected.. Direct Unlock Success... !!! Success !!!! Restart Phone Manually if not done auto... Total Time Take...00:00:24 |
