Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 09-16-2016, 01:32   #1 (permalink)
CloseCOder's Avatar
Member: 2400231
Thanks Meter: 121
SM-J700T Write Cert Fail
So without checking the IMEI of the phone, i rooted it and Unlocked it. It wouldn't get signal so i check the IMEI and it's blacklisted. I then proceed to Reset MSL through Exynos unlock, then write cert through USB but it asks to flash combination file. Ok so i flash the combination file PF2 and retry the process but at the end it still asks to flash combination file, i need help :/
Using Version...1.0.0.0037
Selected Port ssudmdm0000 = COM95
Selected Model SM-J700T1
Selected Task SAM CERT WRITE
ALL SAMSUNG CERT WRITE STARTED..
Searching Phone Please wait...
Phone Found Wait...
TEST MODE OK..
Model := J700T
VER := J700TUVU1APF2/FA60_J700TUVUX1APF2/J700TUVU1APF2/FA60_J700TUVU1APF2
Phone IMEI := 35721807121487
Default MSL NO NEED RESET EFS...
Flash combination flash (Eng firmware) for such phone...
!!! FAIL !!!!
Total Time Take...00:00:45
Even with UART it fails
Selected Port VCP0 = COM20
Phone Found Wait...
TEST MODE OK..
Model := SM-J700T
UNIQID := C000050D032F723
Details. SM-J700T,REV0.5,FA60_J700TUVU1APF2,FA60_J700TUVU1APF2 ,J
Device Knox Warranty is := Void
!!! FAIL !!!!
Total Time Take...00:00:15
Old 09-16-2016, 03:10   #2 (permalink)
Member: 1347382
Thanks Meter: 83
either way wont work because certs are also CPUID locked for this model.
The Following 2 Users Say Thank You to meraz9000 For This Useful Post:
Old 09-16-2016, 04:48   #3 (permalink)
chaudhfa's Avatar
Member: 1590407
Thanks Meter: 145
As well as knox void .. game over
Old 09-16-2016, 14:56   #4 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 395
Some boxes update R/W Cert those models J700T and J700T1 without noticing users!
The Following User Says Thank You to hoang For This Useful Post:
Old 10-01-2016, 03:12   #5 (permalink)
Member: 2286905
Thanks Meter: 6
so there is no way to write a cert to this phone?
Old 10-01-2016, 08:16   #6 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,418
bro log ask u to flash phone with combination file
Old 10-01-2016, 09:18   #7 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 395
If you can read...
Old 10-01-2016, 09:25   #8 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,418
ok
after flashing with comb file
flash phone with normal firmware 5.1.1
then try
Old 10-04-2016, 03:42   #9 (permalink)
CloseCOder's Avatar
Member: 2400231
Thanks Meter: 121
I tried everything and i'm convinced that tripping knox made sure writing cert files not work. Will try on a virgin device with combination file loaded first. Will post results
Old 10-04-2016, 05:04   #10 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 395
its new signature 2.0 device, with cpid cert matching, dont try again or you will get same this result!
Old 01-30-2017, 07:55   #11 (permalink)
Member: 361348
Thanks Meter: 625
plz can somebody share or exchange j700t cert file with me? i av same and more other
The Following User Says Thank You to hippolyte85 For This Useful Post:
Old 01-30-2017, 09:09   #12 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,054
@hippolyte85
Hello
J700T model cert read write added to just restore original cert in case of damaged by other tools or user mistakes.
You can not use other phone certs to other phone they are HWID signed.
Even if GCPro latest update can read/write other device cert to other phones IMEICERT will be always fail.(Unless its patched by other tool.)
The Following 2 Users Say Thank You to stanner_austin For This Useful Post:
Page generated in 0.35939 seconds with 7 queries
