06-13-2016, 20:03 | #1 (permalink) |
Junior Member Join Date: Feb 2007
Member: 449854 Status: Offline Thanks Meter: 5 | unlock log does not show msl anymore Using Version...1.0.0.0033 Selected Model SM-N920P Selected Task SAMSUNG SPRINT UNLOCK Searching ADB device Please wait.. Device Detected... model:= SM-N920P Androids Version:= 5.1.1 Description Version:= nobleltespr-user 5.1.1 LMY47X N920PVPS2AOK3 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ mdm2 ] Baseband:= N920PVPS2AOK3 VER:= N920PVPS2AOK3/N920PSPT2AOK3/N920PVPS2AOK3/N920PVPS2AOK3 Carrier := XAS_USA EFS CSC := XAS Network Mode := 3 Simstatus:= READY ANDROID-ID = 1215fc8b3b500605_0000790F4E Device is not rooted SAMSUNG ALL SPRINT UNLOCKING STARTED... Checking Data... Waiting for Loader... Loader Ok... Direct Unlock Success... !!! Success !!!! Restart Phone Manually if not done auto... Total Time Take...00:00:20 Log Saved |
06-14-2016, 15:21 | #4 (permalink) |
Member: 449854 Status: Offline Thanks Meter: 5 | ok got the msl here is my log trying to get apn settings back, worked once with another phone but some will not work. Using Version...1.0.0.0033 Selected Port VCP0 = COM19 Selected Model SM-G920P Selected Task SAMSUNG READINFO Searching phone... Phone Found Please Wait... Details. SM-G920P,G920P.02,G920PVPU3BOI1,G920PVPU3BOI1,G920PVP U3 Model := SM-G920P UNIQID := 0815F83DEE441B0 Samsung SerialNO:= 00000000000 Device SN:= 0815F83DEE441B02 Phone IMEI := 99000697252256 Phone MEID := A0000050FDE7BB Default MSL NO NEED RESET EFS... ROOT KEY GOOD.. CSC := XAS Device Knox Warranty is := 0 IMEICERT MAYBE NOT IN USE1.. SKEY := 0053 QCOM(QUALCOMM) Type Possible.. IMEI-1 SIGN PASS.. IMEI-2 SIGN PASS.. MEID SIGN PASS.. Phone is SIM-Unlocked.. not detected lock status1. not detected lock status2. Reading Information Finish... Total Time Take...00:00:29 Log Saved Using Version...1.0.0.0033 Selected Port VCP0 = COM19 Selected Task GC AT Reply ASCII := AT+PRECONFG=2,XAS+PRECONFG:2,OKOK Reply Hex := 41542B505245434F4E46473D322C5841530D0A0D0A2B505245 434F4E46473A322C4F4B0D0A0D0A4F4B0D0A Total Time Take...00:00:12 |
06-14-2016, 15:25 | #5 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @fozz18 Hello Did you boot in recovery and confirm csc is now XAS ? Now boot in system and check for apn if still not there ##786# RESET should bring it. As you said its worked once so there is no issue in our solution.. must be you skip or missed some part . i advice you to re do it. Set csc to XAS reboot to recovery confirm its XAS applying. reboot to system check apn if not there use ##786# reset enter msl/spc should work 100% if not something broken in your phone reflash may help. |
06-14-2016, 17:01 | #6 (permalink) |
Member: 449854 Status: Offline Thanks Meter: 5 | should it say # manual mode # -- applying multi-csc... applied the csc-code : XAS successfully applied multi-CSC. if so that part is successful, I've re-flashed the phone (stock 5.1) read msl, reset ##RTN# , re-unlocked the phone, read uart successful, and applied the "AT+PRECONFG=2,XAS" command. still no dice. I'm working on 6 X sm-n920p, 3 X sm-g925p, 3 X sm-g920p, 3 X sm-g930p, and 1 X sm-g935p. all having the same issue. your method worked on 4 sm-g920p previously but thats it. Any other solutions? |
06-14-2016, 17:43 | #7 (permalink) |
Member: 449854 Status: Offline Thanks Meter: 5 | ok so i'm sure this will help someone after doing the procedure recommended by stanner you will still see unable to view the access point name settings, access is restricted for the current user profile. just click add and input the info anyway and it will take. the message will still be there but will not stop you. |
06-14-2016, 18:06 | #8 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello Its basic you have to add apn by your self not gona come automatic. this steps we told to enable apn add/edit option not to add apn automatic. |
06-14-2016, 21:04 | #9 (permalink) |
Member: 449854 Status: Offline Thanks Meter: 5 | never said that, their is a message that says access is restricted for the current user profile where the apn's are. that is the problem I was trying to correct. I understand that you need to enter apn settings manually. |
