04-04-2016, 07:38 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | What is DM-Verity Verification fail? How to Fix with GCProKey. Hello All android by default have dm-verity check on system modification detection to break things like
1) Q: Working device wiped efs. How to fix DRK? 1) Ans: Select box port uart interface. Connect C3303K cable to phone.Use battery tape on BSI or *#0*# to enable uart without root.Select any model in gcpro.Select DRK Repair & wait till process finish. Your phone is repaired. Reflash if need. 2) Q: Non Working device wiped efs. How to fix DRK? 2) Ans: 1). Easy way is get factory COMBINATION file extract bootloader file (aboot.mbn or sboot.bin) make zip flash with gcpro samsung zip flasher. or make tar flash with odin. Now use same step as 1Q. 2). If phone warranty is already void use any custom kernel flash custom recovery and install custom kernel zip. This will bypass drk check and let your phone start. Now use same step as 1Q. 3). Download Full 4 part firmware which include CSC,AP,CP,BL .Full flash with odin. Wait for restart and go to recovery,wipe data,cache & reboot phone. put in download mode again reflash AP firmware only. Check if its start normally if yes use same step as 1Q. If some reason uart can't be enabled by keycodes use ENABLE UART option must root phone. If some reason phone can't be rooted can't enable uart can't start on normal mode. Only way to fix such case is via COMBINATION flash special bootloader (aboot.mbn or sboot.bin) file. 3) Q: How to fix DRK via adb? 3) Ans: 1). Please root phone & make sure its stable on enable usb developer mode select option in samsung tab DRK Repair adb Press start Last edited by stanner_austin; 04-16-2016 at 13:06. Reason: updated |
The Following 20 Users Say Thank You to Faisal_Computer For This Useful Post: |
