07-31-2016, 23:58 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | World First IMEI Write G920T PF1 WITH USB Just reset MSL first by running exynos unlock. Once MSL is reset just use IMEICERT_WRITE_USB. Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM362 Selected Model SM-G920A Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G920T VER := G920TUVU4EPF1/G920TTMB4EPF1/G920TUVU4EPF1/G920TUVU4EPF1 Phone IMEI := 35946206448103 Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update IMEI Ok.. SKEY := 0346 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! This will work on all variants with new security...no need to root or have special files any longer. |
The Following 9 Users Say Thank You to markhaines1985 For This Useful Post: |
08-01-2016, 02:09 | #2 (permalink) | |
No Life Poster Join Date: Oct 2013
Member: 2051392 Status: Offline Thanks Meter: 161 | Quote:
Looks like this is the same as the S7 cert write, S7 models it works but on the Edge Models it doesn't, I just tried G925T on PF1 and it doesn't work. Here's my log Exynos_Unlock: Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM200 Selected Model SM-G925T Selected Task SAMSUNG Exynos Unlock Phone Found Please Wait... Model := G925T Ver := G925TUVU4EPF1/G925TTMB4EPF1/G925TUVU4EPF1/G925TUVU4EPF SN := R58G503RTF IMEI := 35773006103037 UNIQID := 04157DF43877BA1 Direct Unlock Success.. !!! Success !!!! Total Time Take...00:01:06 Writing cert: Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM200 Selected Model SM-G925T Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G925T VER := G925TUVU4EPF1/G925TTMB4EPF1/G925TUVU4EPF1/G925TUVU4EPF1 Phone IMEI := 35773006103037 MSL Address:= Ô»ŒîµPg£Ù‰ RESET EFS FIRST OR USE MSL CODE... !!! FAIL !!!! Total Time Take...00:00:39 | |
08-01-2016, 03:24 | #5 (permalink) | |
Sent from my SM-N920T using Tapatalk | |
08-01-2016, 07:11 | #8 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @banziitox24 Hello Did you retry exynos unlock ? once success use readinfo uart to see msl is reset or not. Also try such phone with uart imeicert write to find out extact bug so i can fix it. |
08-01-2016, 08:44 | #9 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | You can always wipe EFS using Odin and write your cert doesn't matter what android version it is ... Just make sure you Dont! root the device .. |
The Following User Says Thank You to jusmejose For This Useful Post: |
08-01-2016, 12:32 | #11 (permalink) | |
Member: 2532914 Status: Offline Thanks Meter: 1,154 | Quote:
Thanks for all your help! LOL | |
08-01-2016, 18:27 | #12 (permalink) | |
Exynos_Unlock again: Using Version...1.0.0.0035 Selected Port ssudmdm0101 = COM200 Selected Model GT-I5503 Selected Task SAMSUNG Exynos Unlock Phone Found Please Wait... Model := G925T Ver := G925TUVU4EPF1/G925TTMB4EPF1/G925TUVU4EPF1/G925TUVU4EPF SN := R58G503RTF IMEI := 35773006103037 UNIQID := 04157DF43877BA1 Unknown reply1.jYzREYAwDEJnSqOJ/WxNXePtv4VJF9CDg4Pj0BNtSPB8QJQo6ayyH/OJcafmecMHNnHDArt2HLjiC+tFF+TYm2z0BQ== Phone is Already Unlocked.. Direct Unlock Success.. !!! Success !!!! Total Time Take...00:00:30 Log Saved Here's ReadInfo UART Using Version...1.0.0.0035 Selected Port VCP1 = COM12 Selected Model GT-I5503 Selected Task SAMSUNG READINFO Searching phone... Phone Found Please Wait... Details. SM-G925T,REV0.2,G925TUVU4EPF1,G925TUVU4EPF1,G925TUVU4 EP Model := SM-G925T UNIQID := 04157DF43877BA1 Samsung SerialNO:= R58G503RTFF Device SN:= 04157DF43877BA17 Phone IMEI := 35773006103037 Phone MEID := 35773006103037 MSL Address:= Ô»ŒîµPg£Ù‰ ROOT KEY GOOD.. REACTIVATION UNLOCKED... CSC := TMB Device Knox Warranty is := 0 SKEY := 0346 EXYNOS Type Possible.. IMEI-1 CERT_PASS.. IMEI-2 CERT FAIL OR NOT USED.. not detected lock status1. not detected lock status2. Reading Information Finish... Total Time Take...00:00:29 Log Saved And this is WriteCert UART: Using Version...1.0.0.0035 Selected Port VCP1 = COM12 Selected Model GT-I5503 Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := SM-G925T UNIQID := 04157DF43877BA1 Details. SM-G925T,REV0.2,G925TUVU4EPF1,G925TUVU4EPF1,G925TUVU4 EP Phone IMEI := 35773006103037 Device Knox Warranty is := Not Void MSL Address:= Ô»ŒîµPg£Ù‰ RESET EFS FIRST OR USE MSL CODE... !!! FAIL !!!! Total Time Take...00:00:19 Log Saved | |
08-01-2016, 19:02 | #13 (permalink) |
Member: 2532914 Status: Offline Thanks Meter: 1,154 | I had a similar issue with g920w8...I did exynos unlock a couple times but is still showing original MSL Address: Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM366 Selected Model SM-G920W8 Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G920W VER := G920W8VLU3BOL1/G920W8OYA3BOL1/G920W8VLU3BOL1/G920W8VLU3BOL1 Phone IMEI := 35155907663699 MSL Address:= RF8H32ARL1 RESET EFS FIRST OR USE MSL CODE... !!! FAIL !!!! |
08-01-2016, 21:14 | #14 (permalink) |
Member: 2051392 Status: Offline Thanks Meter: 161 | I just did an G920T PF1 and it worked perfectly but still doesnt work for G925T Here's the log Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM211 Selected Model SM-G920A Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := G920T VER := G920TUVU4EPF1/G920TTMB4EPF1/G920TUVU4EPF1/G920TUVU4EPF1 Phone IMEI := 35946206259545 Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update IMEI Ok.. SKEY := 0346 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:03:17 Log Saved |
