07-30-2016, 03:41 | #2 (permalink) |
Freak Poster Join Date: Aug 2014
Member: 2236899 Status: Offline Thanks Meter: 26 | Turn the phone in FTM mode (power+ volume down) root using kingoroot . once root is success ,do not turn off or restart phone. Under android tab in GCP click Frp remove and you R done Sent from my LG-H830 using Tapatalk |
The Following 6 Users Say Thank You to h47assan For This Useful Post: |
08-25-2016, 01:34 | #9 (permalink) |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | ZTE N9518 FRP done!!!!! Using Version...1.0.0.0035 Selected Model ZTE Android Selected Task FRP REMOVE Searching ADB device Please wait.. Device Detected... model:= N9518 Androids Version:= 5.1 Description Version:= zte_warp6-user 5.1 LMY47O 20160219.171939 release-keys Platform:= msm8916 [ qcom ] [ msm ] Warning Baseband is Unknown or damaged.... BusyBox version := 1.18.4 ANDROID-ID = ?_0000D5FCC9 SU Version..kingo 14 Device is Secure Rooted..uid=0 ANDROID FRP REMOVE STARTED... !!! Success !!!! Restarted phone... Total Time Take...00:00:06 |
The Following User Says Thank You to JT man For This Useful Post: |
09-02-2016, 02:29 | #10 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Somebody please help out and describe the steps to root the N9518 with FRP on. Obviously you can't go to the debug menu if FRP is on, so how would you root it with KingRoot? Step by step please, and no PM's not interested in that. Thanks, BillA |
09-02-2016, 15:35 | #11 (permalink) |
No Life Poster Join Date: Feb 2010 Location: kumasi-ghana Age: 32
Member: 1242667 Status: Offline Thanks Meter: 77 | see i just did one with the powerful root and it worked NO ROOT REQUIRED Using Version...1.0.0.0035 Selected Model Selected Task FRP REMOVE Searching ADB device Please wait.. Device Detected... model:= Z812 Androids Version:= 5.1 Description Version:= P816A06-user 5.1 LMY47O 20150511.164322.6785 release-keys Platform:= msm8916 [ qcom ] [ msm ] Baseband:= M8936FAAAANUZM-1.19063.1.19239.1 Network Mode := LTE Simstatus:= READY BusyBox version := 1.18.4 ANDROID-ID = 7fda9a25_0000052DF8 Device is not rooted ANDROID FRP REMOVE STARTED... No ROOT FRP Bypass Started... !!! Success !!!! Restarted phone... Total Time Take...00:00:06 Log Saved Last edited by ostybons; 09-02-2016 at 15:36. Reason: mistake |
09-03-2016, 02:03 | #12 (permalink) | |
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
So one user said need root, you said no root ?? ... pretty confusing... Do you connect the phone in fastboot/dload mode or straight powered up? Is ADB enabled automatically or you have to do something? Seriously guys, need to be a bit more specific. Thanks. | |
09-03-2016, 03:53 | #13 (permalink) | |
How did you enable ADB on the N9518 when you're stuck on the FRP screen? In order to root it with Kingo root PC version, you need to have adb on. | |
09-03-2016, 04:13 | #14 (permalink) | |
Member: 2444830 Status: Offline Thanks Meter: 162 | Quote:
One more thing after root success pc actually tell you so the make sure you don't reboot stay on the ftm mode caused if you reboot you loose root..... Sent from my SM-N930T using Tapatalk | |
09-03-2016, 04:36 | #15 (permalink) | |
Ok never mind, got it done... when setting up WiFi, bring up the keypad, go to help, select any word, share via Google App, in the search box type in "setttings", enable Debugging Mode, select OEM Unlock on, must reboot and you just bypassed the FRP, go thru the setup as normal. For firmware version N9518V1.0.B12 no box is needed, but box is needed for other versions. | |
