09-01-2017, 18:43 | #31 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2300959 Status: Offline Thanks Meter: 41 | [ 29/08/2017 10:50:00 a.m. ] Searching Samsung modem... detected COM5 [ 29/08/2017 10:50:00 a.m. ] Reading phone info... OK [ 29/08/2017 10:50:00 a.m. ] Model: SM-G955F [ 29/08/2017 10:50:00 a.m. ] AP version: G955FXXU1AQC4 [ 29/08/2017 10:50:00 a.m. ] CSC version: G955FOWM1AQC4 [ 29/08/2017 10:50:00 a.m. ] CP version: G955FXXU1AQC4 [ 29/08/2017 10:50:00 a.m. ] Product code: CGU [ 29/08/2017 10:50:00 a.m. ] Phone SN: R58J632XTGL [ 29/08/2017 10:50:00 a.m. ] Unique number: CE04171448D1B02C0C [ 29/08/2017 10:50:00 a.m. ] Reading IMEI... OK [ 29/08/2017 10:50:00 a.m. ] IMEI: 359122086662458 [ 29/08/2017 10:50:00 a.m. ] Reading SN... OK [ 29/08/2017 10:50:00 a.m. ] Phone SN: R58J521573 [ 29/08/2017 10:50:00 a.m. ] Enter MSL: 44562F53560A2B3F623A4E0148273B5B [ 29/08/2017 10:50:00 a.m. ] Bypass MSL... error (2) but why you say me that MSL code is correct if it is error ?? this MSL code is not correct and technical support can not unlock via teamviewer.. then what i do?? check this:same model and different MSL code this erorr is come from wrong msl contact your provider Here is Wrong Msl erorr : Operation: Unlock Selected model: SM-G950F Software version: 29.1 Searching Samsung modem... detected COM117 Reading phone info... OK Model: SM-G950F AP version: G950FXXU1AQF7 CSC version: G950FOXM1AQF7 CP version: G950FXXU1AQF7 Product code: NEE Phone SN: RF8J419BTRL Unique number: CE0317133B37CCCE0C Reading IMEI... OK IMEI: 355***************** Reading SN... OK Phone SN: RF8J4**** Enter MSL: 215A47300B3E2D5C631652390D513F11 Bypass MSL... error (2) Here is Good MSL Log Some Phone : Operation: Unlock Selected model: SM-G950F Software version: 29.1 Searching Samsung modem... detected COM117 Reading phone info... OK Model: SM-G950F AP version: G950FXXU1AQF7 CSC version: G950FOXM1AQF7 CP version: G950FXXU1AQF7 Product code: NEE Phone SN: RF8J419BTRL Unique number: CE0317133B37CCCE0C Reading IMEI... OK IMEI: 35508************ Reading SN... OK Phone SN: RF8J4***** Enter MSL: 3E5414232E1C1758325C5E1A2B514C45 Bypass MSL... OK Unlocking... OK Codes set to 00000000 Rebooting phone... OK Unlock done |
09-01-2017, 19:04 | #32 (permalink) |
Product Supporter Join Date: Feb 2013 Location: UAE
Member: 1881342 Status: Offline Sonork: NA Thanks Meter: 398 | Sir you didn't read and followed service description before use the service please let me share here and find out the fault yourself Please connect your device with z3x read correct serial and imei Do not submit serial if 1st 10 Digit are not same in Both serials follow the image before place order. Please read and check it very carefully |
09-01-2017, 19:05 | #33 (permalink) |
Member: 1881342 Status: Offline Sonork: NA Thanks Meter: 398 | Check here your serial please Phone SN: R58J632XTGL [ 29/08/2017 10:50:00 a.m. ] Unique number: CE04171448D1B02C0C [ 29/08/2017 10:50:00 a.m. ] Reading IMEI... OK [ 29/08/2017 10:50:00 a.m. ] IMEI: 359122086662458 [ 29/08/2017 10:50:00 a.m. ] Reading SN... OK [ 29/08/2017 10:50:00 a.m. ] Phone SN: R58J521573 |
The Following User Says Thank You to gsmfastest For This Useful Post: |
09-01-2017, 19:30 | #34 (permalink) | |
Member: 2300959 Status: Offline Thanks Meter: 41 | Quote:
I'm grateful for your knowledge.. you give a good reply.. ok then can i try submitt with true.. you are the unique person that give me the real reply to my issues.. can i try submit the real serial ?? | |
09-01-2017, 19:45 | #35 (permalink) |
Member: 2300959 Status: Offline Thanks Meter: 41 | i have observation with this service.. in Z3X when you press button read info dont show the real serial to submit and order check: Operation: Info Selected model: SM-G955F Software version: 29.2 Searching Samsung modem... detected COM5 Reading phone info... OK Model: SM-G955F AP version: G955FXXU1AQC4 CSC version: G955FOWM1AQC4 CP version: G955FXXU1AQC4 Product code: CGU Phone SN: R58J632XTGL Unique number: CE04171448D1B02C0C Reading IMEI... OK IMEI: 359122086662458 (SIGN: OK) Done with Samsung Tool PRO v.29.2 but when you press button unlock it shows the real serial to submit and to order MSL code check: Operation: Unlock Selected model: SM-G955F Software version: 29.2 Searching Samsung modem... detected COM5 Reading phone info... OK Model: SM-G955F AP version: G955FXXU1AQC4 CSC version: G955FOWM1AQC4 CP version: G955FXXU1AQC4 Product code: CGU Phone SN: R58J632XTGL Unique number: CE04171448D1B02C0C Reading IMEI... OK IMEI: 359122086662458 Reading SN... OK Phone SN: R58J521573 Enter MSL: canceled Operation aborted Done with Samsung Tool PRO v.29.2 I think it's an important point to people that use Z3X. thank for your knowledge sir. |
The Following User Says Thank You to carloszacamil For This Useful Post: |
09-08-2017, 17:17 | #36 (permalink) |
Member: 2300959 Status: Offline Thanks Meter: 41 | sir can you help me?? resubmited the correct serial and i received the new MSL but it gave error check Operation: Unlock Selected model: SM-G955F Software version: 29.2 Searching Samsung modem... detected COM5 Reading phone info... OK Model: SM-G955F AP version: G955FXXU1AQC4 CSC version: G955FOWM1AQC4 CP version: G955FXXU1AQC4 Product code: CGU Phone SN: R58J632XTGL Unique number: CE04171448D1B02C0C Reading IMEI... OK IMEI: 359122086662458 Reading SN... OK Phone SN: R58J521573 Enter MSL: 3025670046021D0A28211040535B3F32 Bypass MSL... error (2) i dont know to do? i tried submited but it gave error.. can help me please |
09-08-2017, 17:24 | #37 (permalink) | |
Member: 1881342 Status: Offline Sonork: NA Thanks Meter: 398 | Quote:
Your both serials are different do not submit again | |
09-14-2017, 10:36 | #39 (permalink) |
Junior Member Join Date: May 2008 Location: india Age: 35
Member: 783208 Status: Offline Sonork: subairck Thanks Meter: 3 | Your order for 335# Apple id Removing Service Lost Mode By IMEI & Screen-shot of Phone number on Screen {Fresh Imeis High Success Rate} - has processing failure . Please return my payment in paypal |
09-14-2017, 11:36 | #40 (permalink) |
Product Manager Join Date: Jan 2013
Member: 1866816 Status: Offline Sonork: 100.1601293 Thanks Meter: 385 | this servixe not in our web site please check where u submit and if u have credit with us give me ur user name on skype or here i ll check refund ur all pyamnets |
