Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
08-06-2014, 16:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | [Guide] All Huawei (Android) Stock Rom Installation Guide. IF you have downloaded Dload/Update.aap based firmware follow this procedure to install firmware on your device. ROM install Step one : Prepare an SD card, it is recommended to use Kingstone, or Kingmax, size is recommended that more than 1G. Step Two : Formatting SD card (optional). Step Three : copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four : Check the root directory of the SD card you dload UPDATA.APP. Step Five : SD card into the phone is switched on in the main screen, press the Menu key, the system updates -> SD card upgrade -> confirm -> upgrade, backup data, select the backup data; upgrade. Step Six : The upgrade process progress bar shows after the finish of the pending progress bar, the phone automatically restart. OR Step one: Prepare an SD card, it is recommended to use Kingstone, or Kingmax, size is recommended that more than 1G. Step Two: Formatting SD card (optional). step three : copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four: Check the root directory of the SD card you dload UPDATA.APP. Step Five: cell phone turned off, insert the SD card, while pressing the volume up button + volume down key switch button, the phone automatically enters the upgrade mode, and then begin the upgrade in Figure Step Six: After the progress bar to go full fixed, the phone will automatically restart If you do not manually remove the battery. Good Luck. Br Babar Abbasi Last edited by androidlabs; 08-06-2014 at 16:19. |
The Following 15 Users Say Thank You to androidlabs For This Useful Post: |
08-07-2014, 21:27 | #2 (permalink) |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | Flash ROM / Firmware with SP Flash Tool On (MTK) MediaTek Based Huawei Smartphone What's needed:
First of all, make sure that you have MediaTek DA USB VCOM drivers installed. [IMG]http://3.bp.********.com/-1Gxo90bRgIs/T6oifHh6VRI/AAAAAAAABoQ/sXGBr8ZYWNg/s640/drivers.png[/IMG] Flashing the whole ROM First of all open SP Flash Tool, then click Scatter-loading button to load the correct scatter file (MT6575_Android_scatter_emmc.txt or MT6577_Android_scatter_emmc.txt, depending on which phone you have) for your device and ignore any message that may appear. [IMG]http://3.bp.********.com/-RrYRRBm9s1o/T6pekhu6ReI/AAAAAAAABoc/GJXCY5wRMaQ/s640/sp0.png[/IMG]
The process will start and a red progress bar will appear. [IMG]http://1.bp.********.com/-Svb47VuzFUU/T6pesiuFI4I/AAAAAAAABow/pB9El1k6X-I/s640/sp3.png[/IMG]
[IMG]http://3.bp.********.com/-VIozjRN_Kw8/T6petC8e9yI/AAAAAAAABo4/5koWOVnIkWk/s640/sp4.png[/IMG]
[IMG]http://1.bp.********.com/-AVRfz4ExeFU/T6pet9GOFWI/AAAAAAAABpA/owXnn9uTrUs/s640/sp5.png[/IMG]
[IMG]http://4.bp.********.com/-IvFvMBgpN3E/T6peuktNpCI/AAAAAAAABpI/bQNPEVJ6FoA/s640/sp6.png[/IMG]
Flashing only part of the ROM
[IMG]http://3.bp.********.com/-vZsQrYyNFlA/T6pevV8ptjI/AAAAAAAABpU/HGjxFwDowL4/s640/sp7.png[/IMG]
[IMG]http://4.bp.********.com/-tda8yHWu76Y/T6pexQF9pUI/AAAAAAAABpc/LC8E6ZAJlvQ/s640/sp8.png[/IMG]
[IMG]http://1.bp.********.com/-PCFU9ORmLEI/T6peyG1GoyI/AAAAAAAABpg/6v774s9ZAA4/s640/sp9.png[/IMG] [IMG]http://3.bp.********.com/-CkVJDGOrIr8/T6per4bSQCI/AAAAAAAABoo/KsHZ1_Ywq-o/s640/sp10.png[/IMG]
Attention : Please follow the instructions carefully. I will not take any responsibility on whatever may happen with your phone. Very important warning : Always make sure that you trust the sources of the ROM you download and know that it is meant for your phone. After flashing a wrong preloader, your phone will be completely dead (can't be powered on, it will not charge and won't be detected anymore by the computer). Credits : DR_MOOSAVI (from XDA) BR, Babar Abbasi |
The Following 6 Users Say Thank You to androidlabs For This Useful Post: |
08-12-2014, 09:50 | #3 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | I have Huawei G510 i want to erase emmc , can i use this tool, the phone has android.com stoped problem, please help if possible |
08-12-2014, 11:07 | #4 (permalink) |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | Yes this tool can solve your problem u all you need is just sp flashtool flashable firmware please mention full model number which is written on the back of your phone so that i can share flashfile with you. Br, Babar Abbasi |
08-12-2014, 21:47 | #6 (permalink) | |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | Quote:
Br, Babar Abbasi | |
09-03-2014, 15:21 | #9 (permalink) | |
Freak Poster Join Date: Jul 2009
Member: 1065305 Status: Offline Thanks Meter: 112 | Quote:
any guide line u8860 on logo | |
09-12-2014, 23:27 | #11 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1073124 Status: Offline Thanks Meter: 0 | Hello Babar. Can you help me on having my stock rom? Mine is HUAWEI_Y511_firmware_Y511-U10_Android 4.2_V100R001C52B107_Philippine-Globe Hope you can help as i am frustrated already in looking for this. Thanks. |
09-13-2014, 14:23 | #12 (permalink) | |
Br Babar Abbasi | |
The Following User Says Thank You to androidlabs For This Useful Post: |
10-08-2014, 10:25 | #14 (permalink) | |
