Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 08-06-2014, 16:14   #1 (permalink)
androidlabs's Avatar
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
[Guide] All Huawei (Android) Stock Rom Installation Guide.
IF you have downloaded Dload/Update.aap based firmware follow this procedure to install firmware on your device.
ROM install
Step one : Prepare an SD card, it is recommended to use Kingstone, or Kingmax, size is recommended that more than 1G.
Step Two : Formatting SD card (optional).
Step Three : copy a large package path UPDATA.APP to the SD card dload UPDATA.APP.
Step four : Check the root directory of the SD card you dload UPDATA.APP.
Step Five : SD card into the phone is switched on in the main screen, press the Menu key, the system updates -> SD card upgrade -> confirm -> upgrade, backup data, select the backup data; upgrade.
Step Six : The upgrade process progress bar shows after the finish of the pending progress bar, the phone automatically restart.
OR
Step one: Prepare an SD card, it is recommended to use Kingstone, or Kingmax, size is recommended that more than 1G.
Step Two: Formatting SD card (optional).
step three : copy a large package path UPDATA.APP to the SD card dload UPDATA.APP.
Step four: Check the root directory of the SD card you dload UPDATA.APP.
Step Five: cell phone turned off, insert the SD card, while pressing the volume up button + volume down key switch button, the phone automatically enters the upgrade mode, and then begin the upgrade in Figure
Step Six: After the progress bar to go full fixed, the phone will automatically restart If you do not manually remove the battery.
Good Luck.
Babar Abbasi
The Following 15 Users Say Thank You to androidlabs For This Useful Post:
Old 08-07-2014, 21:27   #2 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
Flash ROM / Firmware with SP Flash Tool On (MTK) MediaTek Based Huawei Smartphone
What's needed:
  • USB data cable
  • MediaTek USB VCOM drivers
First of all, make sure that you have MediaTek DA USB VCOM drivers installed.
[IMG]http://3.bp.********.com/-1Gxo90bRgIs/T6oifHh6VRI/AAAAAAAABoQ/sXGBr8ZYWNg/s640/drivers.png[/IMG]
Flashing the whole ROM
First of all open SP Flash Tool, then click Scatter-loading button to load the correct scatter file
(MT6575_Android_scatter_emmc.txt or MT6577_Android_scatter_emmc.txt, depending on which phone you have) for your device and ignore any message that may appear.
[IMG]http://3.bp.********.com/-RrYRRBm9s1o/T6pekhu6ReI/AAAAAAAABoc/GJXCY5wRMaQ/s640/sp0.png[/IMG]
  • Turn off your phone, remove the battery and replace it after some seconds (and don't turn on the phone).
  • Press F9 (or hit Download button) and connect your phone into the computer via USB data cable.
The process will start and a red progress bar will appear.
[IMG]http://1.bp.********.com/-Svb47VuzFUU/T6pesiuFI4I/AAAAAAAABow/pB9El1k6X-I/s640/sp3.png[/IMG]
  • After the red progress bar is complete, there will appear a purple progress bar.
[IMG]http://3.bp.********.com/-VIozjRN_Kw8/T6petC8e9yI/AAAAAAAABo4/5koWOVnIkWk/s640/sp4.png[/IMG]
  • Right after the purple progress bar is complete, a message will appear underneath it:
    “Please insert USB cable in x seconds” and then the download will start right away (you will see the yellow progress bar filling up)
[IMG]http://1.bp.********.com/-AVRfz4ExeFU/T6pet9GOFWI/AAAAAAAABpA/owXnn9uTrUs/s640/sp5.png[/IMG]
  • When the yellow bar is complete, you'll get a popup with a green circle and Download OK message,
    which means that the process has been successfully terminated.
[IMG]http://4.bp.********.com/-IvFvMBgpN3E/T6peuktNpCI/AAAAAAAABpI/bQNPEVJ6FoA/s640/sp6.png[/IMG]
  • You can now safely disconnect your phone and turn it on. The process ends here.
Flashing only part of the ROM
  • In case you want to flash just one part of the ROM, that is also possible. In the shown example, only recovery image will be flashed.
    Deselect all parts except the one(s) you want to flash and then press F9 (or hit Download button).
[IMG]http://3.bp.********.com/-vZsQrYyNFlA/T6pevV8ptjI/AAAAAAAABpU/HGjxFwDowL4/s640/sp7.png[/IMG]
  • The tool will immediately show a warning because not all parts are selected, but you should continue anyway. Safely press Yes to continue.
[IMG]http://4.bp.********.com/-tda8yHWu76Y/T6pexQF9pUI/AAAAAAAABpc/LC8E6ZAJlvQ/s640/sp8.png[/IMG]
  • The download of the chosen partition image will start and after the yellow bar is complete, the popup with the green circle should appear.
[IMG]http://1.bp.********.com/-PCFU9ORmLEI/T6peyG1GoyI/AAAAAAAABpg/6v774s9ZAA4/s640/sp9.png[/IMG]
[IMG]http://3.bp.********.com/-CkVJDGOrIr8/T6per4bSQCI/AAAAAAAABoo/KsHZ1_Ywq-o/s640/sp10.png[/IMG]
  • Please note that, even though it isn't mandatory to select it on the list of images to flash,
    preloader file must be present in the same folder as the other partition(s) that you want to flash, or else phone will not be able to enter into download mode.
Attention : Please follow the instructions carefully. I will not take any responsibility on whatever may happen with your phone.
Very important warning : Always make sure that you trust the sources of the ROM you download and know that it is meant for your phone. After flashing a wrong preloader, your phone will be completely dead (can't be powered on, it will not charge and won't be detected anymore by the computer).
Credits : DR_MOOSAVI (from XDA)
BR,
Babar Abbasi
The Following 6 Users Say Thank You to androidlabs For This Useful Post:
Old 08-12-2014, 09:50   #3 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
I have Huawei G510 i want to erase emmc , can i use this tool, the phone has android.com stoped problem, please help if possible
Old 08-12-2014, 11:07   #4 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
Yes this tool can solve your problem u all you need is just sp flashtool flashable firmware please mention full model number which is written on the back of your phone so that i can share flashfile with you.
Br,
Babar Abbasi
Old 08-12-2014, 21:35   #5 (permalink)
prasutirur's Avatar
Member: 1541938
Sonork: kerala
Thanks Meter: 29
I have huawei acsend mate mt1-u06 android logo only
i'm try to flash but always error
pls help anyone
Old 08-12-2014, 21:47   #6 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
pls help anyone
Here is the link to need rom and there are bunch or official and custom roms available for your device i hope they may help you Click Here do let me know if your need any further assistance. Good Luck.
Br,
Babar Abbasi
Old 08-12-2014, 22:14   #7 (permalink)
prasutirur's Avatar
Member: 1541938
Sonork: kerala
Thanks Meter: 29
huawei mt1-u06 updating time this error E: failed to mount /cache ( invalid argument )
pls help me
Old 08-12-2014, 22:18   #8 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
pls help me
Are you updating from recovery ? Is your phone rooted?
Old 09-03-2014, 15:21   #9 (permalink)
Member: 1065305
Thanks Meter: 112
Good Luck.
Babar Abbasi
using this methad u8860 after unpacking installation faild
any guide line
u8860 on logo
Old 09-03-2014, 16:03   #10 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
any guide line
u8860 on logo
Format sd card with fat32 method and then put the dload folder into root of your memory card and try again. Good Luck
Br,
Babar Abbasi
Old 09-12-2014, 23:27   #11 (permalink)
Member: 1073124
Hello Babar. Can you help me on having my stock rom?
Mine is HUAWEI_Y511_firmware_Y511-U10_Android 4.2_V100R001C52B107_Philippine-Globe
Hope you can help as i am frustrated already in looking for this.
Thanks.
Old 09-13-2014, 14:23   #12 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
Thanks.
Y511-U30 try from here
Babar Abbasi
The Following User Says Thank You to androidlabs For This Useful Post:
Old 10-03-2014, 21:13   #13 (permalink)
seyram's Avatar
Member: 1759904
Thanks Meter: 6
need huawei y220-u00 rom and windows 7 ultimate drivers please help
Old 10-08-2014, 10:25   #14 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
For drivers you can install huawei pc suite from here http://forum.gsmhosting.com/vbb/f929...hones-1846018/ and rom is posted on the other thread. Good Luck.
Br,
Babar Abbasi
Old 10-21-2014, 12:05   #15 (permalink)
Member: 276082
Thanks Meter: 113
anyone try s7-721u with this solution?
Page generated in 0.24703 seconds with 9 queries
