Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
10-03-2016, 14:12 | #16 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Quote:
Unfortunately, Qualcomm Factory Firmwares can't be extracted or converted from normal firmwares, It can be only leaked from the company itself, BR Sent from my iPhone 6 using Tapatalk. | |
The Following 3 Users Say Thank You to MiRoOo For This Useful Post: |
11-15-2016, 18:36 | #21 (permalink) | |
Freak Poster Join Date: Oct 2014 Location: black house
Member: 2280366 Status: Offline Thanks Meter: 19 | Quote:
working phone? if the answer yes please can you tell us how we can do that?? thank you so much | |
11-16-2016, 03:54 | #22 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Basel Age: 43
Member: 378892 Status: Offline Thanks Meter: 51 | CM2QLM software can read firmware from working phoneforum.gsmhosting.com/vbb/f296/chinese-miracle-2-qlm-qualcomm-v1-03-msm8212-msm8612-zte-yu-alcatel-more-2155299/ |
The Following User Says Thank You to chlakh11787 For This Useful Post: |
11-26-2016, 09:31 | #23 (permalink) | |
Insane Poster Join Date: Nov 2009 Location: iran .. sari
Member: 1168670 Status: Offline Thanks Meter: 20 | Quote:
g630-u10 g6-u10 | |
12-08-2016, 10:40 | #25 (permalink) |
Freak Poster Join Date: May 2013
Member: 1935677 Status: Offline Thanks Meter: 22 | [QUOTE=MiRoOo;11982658][CENTER]HUAWEI Y625-U32 Unbrick & Flashing Guide Summary of The Problem ---------------------------------------------------------------- Huawei Y625 phone is one of the worst phones in the market, Phone have a lot of problems which is related to EMMC, as a result, phone will have one of these cases, (stuck at logo, FCs msgs and Encryption unsuccessful problem) Now to fix those problems we need to re-program (restructure) that EMMC, But with that model it's a little hard process, In most cases phone won't go to Recovery so you can flash FWs from there, and if it enters Recovery, it will show error while flashing, Now, since this is a Qualcomm based phone, that means it has a Qualcomm Download mode (qdloader), From there we are going to do whatever we want! Unbrick/Flashing Guide ------------------------------------------------------------- #1 Enable QDloader Mode ---------------------------------------------- 1. Disassemble the phone, 2. Short these two pins with a tweezers, 3. Connect phone to PC (without battery), 4. Check Device Manager > Ports, 5. Now your phone in Qualcomm Download Mode, Let's move to the next part. #2 Flashing the phone ------------------------------------------- 1. Download required files from Download Section, 2. Run Huyie Download tool as Administrator, 3. Follow these images, 4. Disconnect the phone and Power it on, You're done Download Section ---------------------------------------------- Huawei Y625-U32 Firmware < H E R E > < The tool is included with the firmware > This is not an SD_Upgrade package, This is the factory firmware which is used to flash the phone in Qualcomm Download Mode. Final Word -------------------------- This method not only works with Y625-U32, it should work for all Huawei Qualcomm based phones, but you'll need to find the Testpoint and the Factory firmware. I have tested this method myself with a lot of Y625, and they're just working fine now. [FONT=Courier New][SIZE=4][FONT=Century Gothic] In case this guide was helpful for you, thanks for information but sir dowanload link not working so please give me working link |
12-28-2016, 00:54 | #29 (permalink) |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | [GUIDE] Unbrick and Flash Y625-U32 (EncUnsuccess - 9008) As i mentioned earlier, there is no solution that works 100% for a corrupted EMMC, even Re-Programming it via ISP using a professional tool may not fix it, In this case only replacing the EMMC will help, Best Regards Sent from my iPhone using Tapatalk |
The Following 2 Users Say Thank You to MiRoOo For This Useful Post: |
