Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
01-31-2017, 11:41 | #1 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | Honor H30-U10 Imei NULL How to fix imei write nv file write bur same IMEI NULL any best tool write for imei |
03-19-2017, 07:25 | #6 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Please read the the thread from beginning, you can get your expect solution. Send from my SM-G928F using Tapatalk
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
08-24-2017, 05:35 | #9 (permalink) |
Cheater -Don't Deal with him- Join Date: Oct 2012 Location: India
Member: 1819112 Status: Offline Sonork: 100.1792895 Thanks Meter: 23 | Try This Method |
12-22-2018, 13:05 | #13 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Alipur
Member: 2683134 Status: Offline Thanks Meter: 59 | New Working Solution is here read compleate article here Huawei Honor 3C H30-U10 IMEI Repair Solution 100% Tested Without Box Only Thanks Button |
02-21-2019, 19:05 | #14 (permalink) |
Freak Poster Join Date: Jul 2016 Location: Chile Age: 41
Member: 2601431 Status: Offline Thanks Meter: 35 | Sometimes when the we read the phone and the imei is there but in the screen *#06# appears NULL, we need to format all the partitions (Except bootloader) and re-flash de phone again. The steps are: Write memory with spflashtools v3 to unlock the bootloader with the secro scatter loaded. Flash secro. Then format all partitions except bootloader. (Very important) Flash de firmware (In my case B108 worked). Now you can write the imei via adb (You will need root first, you can use KingoRoot) or you can flash with tools like Nck via SpMeta connecting the phone powered off. The imei should appear now. |
The Following User Says Thank You to henrucci For This Useful Post: |
