Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
04-16-2018, 05:14 | #1 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2621555 Status: Offline Thanks Meter: 3 | How to Enable OEM Unlocking with Bootloop Phone How shall I enable it so can use fast boot commands? Kindly assist. Thank you |
The Following User Says Thank You to minrin For This Useful Post: |
04-16-2018, 06:43 | #3 (permalink) |
Member: 2621555 Status: Offline Thanks Meter: 3 | Hello..thank you for the reply. I can't flash it thru SD method since when I boot to recovery mode it keeps on restarting as well. When in fastboot mode it is not possible also since FRP is locked. Need to navigate developer options enable oem unlock but since I can't boot my phone i can't enable it. |
04-19-2018, 01:44 | #6 (permalink) |
Member: 2621555 Status: Offline Thanks Meter: 3 | Unlocking Bootloader via Miracle Box Success but FRP still lock Hi I used Miracle Box > Unlock Bootloader, the box confirmed unlocking bootloader is ok but then FRP lock in green text still appeared in fastboot mode. |
