Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
06-10-2017, 20:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | HOW to TWRP recovery and ROOT GR3 2017 or P8 lite 2017 ( PRA-LA1 & LX1 )! hello everyone people who have this device and looking for any method to root their device without any risk luckily i have this device too so, as i have seen there's not enough thread about this model in the internet then i decided to share my knowledge the device spec GSM / HSPA / LTE Body Dimensions 147.2 x 72.9 x 7.6 mm (5.80 x 2.87 x 0.30 in) Weight 147 g (5.19 oz) SIM Dual SIM (Nano-SIM, dual stand-by) Display Type IPS LCD capacitive touchscreen, 16M colors Size 5.2 inches (~69.5% screen-to-body ratio) Resolution 1080 x 1920 pixels (~424 ppi pixel density) Multitouch Yes - Emotion 5.0 UI Platform OS Android 7.0 (Nougat) Chipset HiSilicon Kirin 655 CPU Octa-core (4x2.1 GHz Cortex-A53 & 4x1.7 GHz Cortex-A53) GPU Mali-T830MP2 Memory Card slot microSD, up to 256 GB (uses SIM 2 slot) Internal 16 GB, 3 GB RAM 64 GB, 4 GB RAM - India Camera Primary 12 MP, autofocus, LED flash Features Geo-tagging, touch focus, face/smile detection, panorama, HDR Video 1080p@30fps Secondary 8 MP, f/2.0, 1080p Sound Alert types Vibration; MP3, WAV ringtones Loudspeaker Yes 3.5mm jack Yes - Active noise cancellation with dedicated mic Comms WLAN Wi-Fi 802.11 b/g/n, Wi-Fi Direct, hotspot Bluetooth 4.1, A2DP, EDR, LE GPS Yes, with A-GPS, GLONASS NFC Yes (market dependent) Radio FM radio USB microUSB 2.0, USB On-The-Go Features Sensors Fingerprint (rear-mounted), accelerometer, proximity, compass Messaging SMS(threaded view), MMS, Email, Push Mail, IM Browser HTML5 Java No - XviD/MP4/H.264/WMV player - MP3/eAAC+/WMA/WAV/Flac player - Document viewer - Photo/video editor Battery Non-removable Li-Ion 3000 mAh battery to be continue..... |
The Following User Says Thank You to xx0o0xx1 For This Useful Post: |
06-10-2017, 20:34 | #2 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | how to root first u have to unlock the bootlaoder https://emui.huawei.com/en/plugin/unlock/index then after succefull unlock download this file http://www.mediafire.com/file/9qz71t...017+%23Devx.7z extract it the file contain root file ( suemui ) and the twrp recovery (gr3-2017 twrp ) ] use fastboot steps to enter t0 fastboot by turn off the device and then hold volume down and attach usb cable flash the recovery write this command --- fastboot flash recovery gr3-2017-twrp.img fastboot reboot --- the device should reboot now enter the recovery mode install the root ( suemui ) file which has being extracted hope if i helped anyone needed that ---- if u like the thread pls be positive and press thanks or leave reply if u need any help #Devx Last edited by xx0o0xx1; 06-10-2017 at 20:40. |
07-12-2017, 19:29 | #4 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | use adb to get into twrp use this command ; adb reboot recovery ; --- feed back pls |
07-20-2017, 00:41 | #6 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | trust me it doesn't matter even if u removed the su app it gives all apps access to to root |
08-03-2017, 03:30 | #7 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2743495 Status: Offline Thanks Meter: 0 | prob hey bro , after i did this step use adb to get into twrp use this command ; adb reboot recovery ; i get this msg daemon not running. starting it now at tcp 5073 can u help me to fix it |
08-14-2017, 20:41 | #9 (permalink) | |
Member: 2033150 Status: Offline Thanks Meter: 624 | Quote:
try this cmd adb kill-server or reinstall adb good luck | |
08-14-2017, 20:44 | #10 (permalink) | |
second , if u r lucky enough which i dont think ur device FRP state should be OFF post here info , and i will help as much i can . | |
10-20-2017, 05:33 | #14 (permalink) |
Crazy Poster Join Date: Mar 2016
Member: 2548422 Status: Offline Thanks Meter: 11 | All official firmware here https://romfirmware.com/category/huawei Sent from my Redmi Note 2 using Tapatalk |
The Following User Says Thank You to kujangsbj For This Useful Post: |
