Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 09-09-2014, 12:01   #1 (permalink)
Member: 2089652
Sonork: 100.1663028
Thanks Meter: 29
Huawei Ascend G610-U20 flashing hang on logo only vibrate solutation 10000 %%% tested
hi
dear all of my friends G610-U20 is a critical phone i have been suffering many days for this phone
finally i got the solution
it was framware fault
here is the framware link
http://pan.baidu.com/s/1kTjzKyz
password is-
need to flash this stock rom .
if u like my post please press the thanks button...
Last edited by androidlabs; 04-23-2015 at 20:37. Reason: password removed due to violation of forum rules
The Following 7 Users Say Thank You to the_faker For This Useful Post:
Old 09-10-2014, 09:20   #2 (permalink)
ZIYAAD STRYKER's Avatar
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
bad archive im downloading again doesnt ask for password!!!
Old 09-11-2014, 19:25   #3 (permalink)
Member: 2089652
Sonork: 100.1663028
Thanks Meter: 29
Not need the password but file tested 10000000000000%%%%
Old 09-16-2014, 17:12   #4 (permalink)
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
please check link again thx
The Following User Says Thank You to ZIYAAD STRYKER For This Useful Post:
Old 09-18-2014, 17:10   #5 (permalink)
androidlabs's Avatar
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
Originally Posted by the_faker View Post
hi
Ascend_G610_firmware_G610_U20_Android_4.2_Emotion_ UI_V100R001C00B115CUSTC433D003_Middle_East-Channel_05021GDF_www.MihanGSM.com.rar_??????|??? ??-?????
password is- Android Rom
is that a flash tool firmware or sd card upgrade ?
The Following User Says Thank You to androidlabs For This Useful Post:
Old 09-19-2014, 09:06   #6 (permalink)
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
it has both via usb n micro sd when i put update.app in dload folder on micro sd card doesnt find update.app on recovery but find the folder
when flash via flashtool i get an error detects phone im uploading pic, can any 1 help plz
Old 09-19-2014, 11:22   #7 (permalink)
Member: 2089652
Sonork: 100.1663028
Thanks Meter: 29
when you get error
you need to go sptool/window/write memory optation
there are two optation 1.nand flash 2.EMMC
select emmc
& open raw data select
Emmc file from g610-u20 folder
then write the memory
after sometime done
show the green circle
then flash with sptool as usual..........
The Following 2 Users Say Thank You to the_faker For This Useful Post:
Old 09-19-2014, 11:30   #8 (permalink)
meeza_84's Avatar
Member: 279362
Sonork: 100.1594141
Thanks Meter: 500
bro use latest ver (SP Flash Tool v5.1352.01)
The Following User Says Thank You to meeza_84 For This Useful Post:
Old 09-19-2014, 11:32   #9 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
Do not need to update via recovery just formate the memory card with fat32 method put the dload folder into the root of your memory card and put the card back into the phone and at that point all you need to do is power off the phone press volume up + volume down and power keys together until the phone starts flashing itself wait for couple of minutes and your phone will be fine. Good Luck
Br,
Babar Abbasi
Old 09-20-2014, 10:20   #10 (permalink)
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
when vol up + down + power is pressed phone start in android recovery doesnt start flashing formated card fat32 created new folder placed update.app still same!
Old 09-20-2014, 10:29   #11 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
Please follow the steps. http://forum.gsmhosting.com/vbb/f929...guide-1845252/
Br,
Babar Abbasi
Old 09-20-2014, 12:26   #12 (permalink)
Member: 2089652
Sonork: 100.1663028
Thanks Meter: 29
memory card method dont work plzzz try to flash with sptool if dont work plzz
contact with me..........
Old 09-22-2014, 14:20   #13 (permalink)
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
hi! phone doesnt work with memory card n sptool tool get above error with new sp flash tool it freezes!! phone back to customer!! thx anyway
Old 09-25-2014, 21:10   #14 (permalink)
Member: 1186634
Thanks Meter: 11
hi every body ,
i have a y300 water damage ,this problume is falash light is on when i put bettry.
plz tell me any solution .
[email protected]
Old 09-25-2014, 22:55   #15 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
Originally Posted by luckyali1985 View Post
hi every body ,
[email protected]
Hello brother you are in wrong section for water damage phone solution i suggest you to open a new thread in huawei hardware repair section or look for the the same thread already posted on that section. Good Luck
Br,
Babar Abbasi
Page generated in 0.22314 seconds with 10 queries
