Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
10-29-2017, 21:05 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | Huawei flashing using edl mode , open thread discussion recently Huawei Co, since it got oem lock and ofc locked bootloader and ofc it doesn't really matter when u have locked FRP . when u need to unlock or do whatever to ur device u can not . so, if any user try to do some action with his device it would go to bricky toy . since the only method to flash ur device using sd card and mostly it doesnt work for a reason ,i'm not gonna go through ... or u may need to use dc phoenix , they have the fac algo and using the backdoor method ,, seems they are auth from Huawei .. now we are on the box's and smart tools door and knocking it ,, the point is they all use the edl mode (emergency download ) so , im working on some issue with a Huawei Y6 scc-u21 stuck at boot with locked bl and frp and no recovery , just fastboot access .. ---- I've tried to use dc method but, it doesn't work with me and the team honestly got my credit back , and asked me to replace the whole mother board , lol . that's ugly ... anyway , the device has Qcom cpu inside , why can't i handle it like any qualcomm device , using any downloader like qfil ? ok first u need the map file and the programmer file also , which mean u need a separated file system ( good luck to get it or back ur devic up , using any founded tool and yeah ofc since SAHARA u can't backup ur device bcz emmc won't be shown to back it up ) any way u will need a qfil firmware .. now the next step is , ur gonna need to put ur device to the edl mode .. either ur adb is somehow working !! just run PHP Code: ,, after a successful connection and exact firmware u can try with qfil , on my side i'm stuck at ERROR: function: sahara_rx_data:194 Unable to read packet header. Only read 0 bytes. ERROR: function: sahara_main:854 Sahara protocol error ERROR: function: main:265 Uploading Image using Sahara protocol failed Download Fail:Sahara Fail:QSaharaServer Fail:Process fail Finish Download .. i guess that back to the bootloader status which is locked or simply i need to change trying with another pc or usb port ... i just need some pple to share me their knowledge , in case someone is interest... luck all ya |
10-31-2017, 01:35 | #4 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | UPDATE : BOOM i got it done and it works well as it said on the title , finally after hard work the idea got worked , thanks to mr Alex - BrKa , who helped me , thanks my friend . will make new thread with main method . thanks |
The Following 3 Users Say Thank You to xx0o0xx1 For This Useful Post: |
11-01-2017, 20:34 | #10 (permalink) | ||
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
(y530, y560, etc.) Quote:
and ... what is the model of huwaei that you posted picture above ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | ||
