Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
10-31-2014, 11:20 | #1 (permalink) |
Junior Member Join Date: Mar 2013 Location: Romania
Member: 1893964 Status: Offline Thanks Meter: 7 | Huawei GL07S emobile lte japan http://gl07s.nakayuki.net |
01-17-2018, 17:23 | #7 (permalink) |
Freak Poster Join Date: May 2007 Location: Kumasi;Ghana\west africa Age: 38
Member: 510345 Status: Offline Thanks Meter: 40 | check this CUSTOM ROM ON THE HUAWEI ASCEND P2 BASED ON ANDROID 4.4.2 KITKAT Download the P6 flashable zip file here. Download ADB and fastboot to your Windows computer. Download the OpenRecovery you want from here. Extract the ADB, Fastboot and Recovery files to the desktop and transfer the recovery.img file over to the same folder as ADB and fastboot. In the same folder, open the command windows by holding the Shift key and right-clicking the mouse on a white space where there is no file and selecting the “open command windows here’ option from the new menu. Type the first command: “adb reboot bootloader”. Press Enter. Type the second command: “fastboot flash recovery recovery.img”. Press Enter. Type the third command: “fastboot reboot”. Press Enter. Press the “Power” + Volume Up + Volume Down” during the startup and select recovery from the menu. You are now about to wipe the data on your handset. You must take a NANDroid backup now, or backup using any other method of your choice, such as the Titanium app from Google Play. Select “Wipe” and swipe to the factory reset. Select ‘Wipe” format data. Select the “Advanced” and “ADB Sideload” and swipe to start the download. Transfer the flashable zip file to the same folder as ADB, Fastboot and the recovery image. Open the command windows again. Type “adb sideload “the-zip-name”.zip and substitute “the-zip” for the real zip file name. Download the homemade ROM here. Install the homemade ROM the same way you flashed the zip file above from the command line. Download the Omni ROM here. Install it the same way once again, using the command line. Wipe the delvik cache and other caching options to ensure a smooth process. Flash Google Gapps here via the command line again or you can upload Gapps from inside recovery by going to install > uploading the zip file. copied from somewhere |
