Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 10-31-2014, 11:20   #1 (permalink)
Member: 1893964
Thanks Meter: 7
Huawei GL07S emobile lte japan
if anyone has this phone and encountered problems with the firmware, here are the files that helped me bring one back to life. hope it helps.
http://gl07s.nakayuki.net
Old 11-04-2014, 15:01   #2 (permalink)
Member: 1893964
Thanks Meter: 7
http://gl07s.nakayuki.net/public
sorry for the mistake
Old 11-04-2014, 16:54   #3 (permalink)
onz
onz's Avatar
Member: 2012334
Sonork: 100.1658100
Thanks Meter: 777
link not working bro it gives error 403 Forbidden
Old 11-05-2014, 08:30   #4 (permalink)
Member: 1893964
Thanks Meter: 7
try this http://gl07s.nakayuki.net/public/
The Following User Says Thank You to anna_tns For This Useful Post:
Old 01-26-2016, 06:21   #5 (permalink)
mcjepoy_12's Avatar
Member: 1304373
Thanks Meter: 31
badly need my phone to unlock.help please on how to unlock this model.icant root it.always fails...
Old 12-28-2017, 03:21   #6 (permalink)
zebafridi's Avatar
Member: 2304199
Sonork: 100.1656573
Thanks Meter: 203
Please Guide this phone
How To flash this Gl07S
Old 01-17-2018, 17:23   #7 (permalink)
ASIEDU ANNOR's Avatar
Member: 510345
Thanks Meter: 40
check this
CUSTOM ROM ON THE HUAWEI ASCEND P2 BASED ON ANDROID 4.4.2 KITKAT
Download the P6 flashable zip file here.
Download ADB and fastboot to your Windows computer.
Download the OpenRecovery you want from here.
Extract the ADB, Fastboot and Recovery files to the desktop and transfer the recovery.img file over to the same folder as ADB and fastboot.
In the same folder, open the command windows by holding the Shift key and right-clicking the mouse on a white space where there is no file and selecting the “open command windows here’ option from the new menu.
Type the first command: “adb reboot bootloader”.
Press Enter.
Type the second command: “fastboot flash recovery recovery.img”.
Press Enter.
Type the third command: “fastboot reboot”.
Press Enter.
Press the “Power” + Volume Up + Volume Down” during the startup and select recovery from the menu.
You are now about to wipe the data on your handset. You must take a NANDroid backup now, or backup using any other method of your choice, such as the Titanium app from Google Play.
Select “Wipe” and swipe to the factory reset.
Select ‘Wipe” format data.
Select the “Advanced” and “ADB Sideload” and swipe to start the download.
Transfer the flashable zip file to the same folder as ADB, Fastboot and the recovery image.
Open the command windows again.
Type “adb sideload “the-zip-name”.zip and substitute “the-zip” for the real zip file name.
Download the homemade ROM here.
Install the homemade ROM the same way you flashed the zip file above from the command line.
Download the Omni ROM here.
Install it the same way once again, using the command line.
Wipe the delvik cache and other caching options to ensure a smooth process.
Flash Google Gapps here via the command line again or you can upload Gapps from inside recovery by going to install > uploading the zip file.
copied from somewhere
Page generated in 0.14891 seconds with 8 queries
