Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
10-19-2015, 05:54 | #1 (permalink) |
No Life Poster Join Date: May 2009
Member: 1024748 Status: Offline Thanks Meter: 53 | huawei h30-u10 vibrate only |
10-19-2015, 06:13 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: pakistan hafizabad
Member: 700741 Status: Offline Sonork: 100.1617188 Thanks Meter: 409 | Honor 3c [H30-u10] International Device. Full Backup Current System Useing Mtkdroid Tool. Stock Android 4.2.x Version Jelly Bean Firmware. Usb Cable And The Latest Drivers MTK Driver. Downloading:- Download SP Flash Tool.zip Honor3CBootUnlock.zip USB Driver / Miror link Complete Step-By-Step To The Instructions:- Install The Required Mtk Usb Drivers. Unzip Sp Flash Tool.zip On Your Pc Unzip Honor3cbootunlock.zip On The Computer. Execute “FlashTool.exe” On The Computer. Click The “scatter-loading“, Then Select “MT6582_Android_scatter” File Is Placed In The “Honor3CBootUnlock” Folder. Click On The Window Menu, Check The “write Memory“. A New Tab Named Write Memory Should Appear. Write Memory Tab, Click To Open The Original Data And Select “preloader_huawei82_wet_jb5.bin“. Set The Memory Is Set To “EMMC“, The Start Address Is Set To as “0x800” And Container Length “0x1B0EC“. Finally, Click On The Write Memory Button. Go To The Download Tab, Click On The “download” Button. Make Sure You Have Disconnected The Usb Cable. Check The “DA DL All With Check Sum” Option. A Download Warning Message Should Pop Up, Click “yes”. Reconnect The Phone In Meta Mode By Connecting It To Pc Via Usb Cable And Power Without Its Battery Inserted. Wait A Few Minutes Until Complete. & flash spflasher |
The Following User Says Thank You to MALIKTARIQ For This Useful Post: |
10-19-2015, 06:19 | #3 (permalink) | |
Member: 1024748 Status: Offline Thanks Meter: 53 | Quote:
10-19-2015, 07:13 | #4 (permalink) | |
11-14-2017, 12:36 | #5 (permalink) |
Freak Poster Join Date: Dec 2012 Location: chawinda
Member: 1861126 Status: Offline Sonork: [email protected] Thanks Meter: 32 | but huawei h30-l01 after scatter flash only vobrate cannot dedect on pc help me |
