Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 09-22-2015, 13:32   #1 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
HUAWEI honor 3c H30-U10 After Flash Only Vibrate
HUAWEI honor 3c update software with dload app option with sdcard update successfull but TOUCH Not working
after Downgrade software With dload app sdcard than set only vibrate
did not write any file only read info
CPU TYPE:MT6582
Hardware version:CA01
Software version:0001
SecCfgVal :0x00000000
BromVersion :0xFF
BLVersion :0x01
>>Boot downloading complete!
Need Solution?????
Old 09-22-2015, 18:07   #2 (permalink)
Member: 1948608
Thanks Meter: 1,744
Try to revert back to original Jelly Bean firmware via sptool
Old 09-23-2015, 07:21   #3 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
CPU TYPE:MT6582
BromVersion :0xFF
BLVersion :0x01
Need Solution?????
Here is direct link to firmware HUAWEI H30-U10 Firmware
Good Luck!
The Following 2 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 09-23-2015, 07:48   #4 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
its sd card UPDATE.APP just make dload folder on sd card then copy update.app in dload folder then press volum up and down then power on phone will go to sd update mode.
Old 09-23-2015, 07:51   #5 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
how to revert dear this click power buttton only vibrate
did not show pink screen....
Old 09-23-2015, 07:57   #6 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
i have not other firmware i think u need to write bin file readed from working phone. if still failed then hardware problem mostly emmc damage.
Old 09-23-2015, 08:08   #7 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
EMMC FINE sir
Working Fone just downgrade ans set vib..........
still need B129 firmware with sp tool flashing..........
w8ing
Old 09-23-2015, 10:42   #8 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
FOUND THIS FILE But Flashing Error With SPTOOL
H30-U10_Firmware_V100R001C900B129_Saudi Arabia_Android 4.2_EMUI 2.0_2
Old 09-24-2015, 08:36   #9 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
Problem Solve .............
Old 10-09-2015, 13:39   #10 (permalink)
Member: 2470397
pls give file i also h30u10 only vibrat after updat
Old 10-27-2015, 09:23   #11 (permalink)
Member: 2275175
brother boot unlock karoooo
Old 10-31-2015, 10:25   #12 (permalink)
aliburhan1's Avatar
Member: 1520256
Sonork: 100.1612582
Thanks Meter: 137
How did you solve problem. I am having same phone in same condition.
Old 10-31-2015, 16:13   #13 (permalink)
aliburhan1's Avatar
Member: 1520256
Sonork: 100.1612582
Thanks Meter: 137
Problem Solved
If some one has this kind of issue. Send PM
The Following 2 Users Say Thank You to aliburhan1 For This Useful Post:
Old 11-12-2015, 07:30   #14 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
Just Unlock Boot......................only
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post:
Old 12-11-2015, 16:36   #15 (permalink)
Member: 2275175
Wink Honer 3c onley Vibret Solution
guys plz Open the SP_Flash_Tool_v3.1328.0.183 This version
ok guys
Page generated in 0.22688 seconds with 8 queries
