Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
09-22-2015, 13:32 | #1 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | HUAWEI honor 3c H30-U10 After Flash Only Vibrate after Downgrade software With dload app sdcard than set only vibrate did not write any file only read info CPU TYPE:MT6582 Hardware version:CA01 Software version:0001 SecCfgVal :0x00000000 BromVersion :0xFF BLVersion :0x01 >>Boot downloading complete! Need Solution????? ??? ?? ? |
09-23-2015, 07:21 | #3 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Quote:
Here is direct link to firmware HUAWEI H30-U10 Firmware Good Luck! | |
The Following 2 Users Say Thank You to >>PakFones<< For This Useful Post: |
09-23-2015, 07:48 | #4 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | its sd card UPDATE.APP just make dload folder on sd card then copy update.app in dload folder then press volum up and down then power on phone will go to sd update mode. |
09-23-2015, 08:08 | #7 (permalink) | |
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | Quote:
EMMC FINE sir Working Fone just downgrade ans set vib.......... still need B129 firmware with sp tool flashing.......... w8ing | |
09-23-2015, 10:42 | #8 (permalink) |
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | FOUND THIS FILE But Flashing Error With SPTOOL H30-U10_Firmware_V100R001C900B129_Saudi Arabia_Android 4.2_EMUI 2.0_2 |
10-31-2015, 16:13 | #13 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Ujmair Mobiles Hassanabdal Age: 37
Member: 1520256 Status: Offline Sonork: 100.1612582 Thanks Meter: 137 | Problem Solved If some one has this kind of issue. Send PM |
The Following 2 Users Say Thank You to aliburhan1 For This Useful Post: |
11-12-2015, 07:30 | #14 (permalink) |
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | Just Unlock Boot......................only |
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post: |
