Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
12-19-2015, 15:38 | #17 (permalink) | |
Junior Member Join Date: Dec 2015
Member: 2503158 Status: Offline Thanks Meter: 0 | Quote:
12-19-2015, 21:21 | #20 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Always remember.. Always download from official source.. Don't use files downloaded by 3rd party sources.. I had face same in g610 and was only resolved by official firmware ftom official web.. |
01-10-2016, 13:07 | #23 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Today I"M Done With This Firmware By SD Card Upgrade Honor 3C (U10) B320 EMUI 3.0 KitKat International Firmware International Honor 3C (H30-U10) has finally received the official B320 Emotion UI 3.0 KitKat firmware update from Huawei in South East Asian countries including Malaysia. You can download this firmware in Update.app format via the direct download link given below. This firmware can easily be installed on Honor 3C sets in India, Pakistan and Iran. Firmware Download Details
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 9 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
05-15-2016, 08:18 | #27 (permalink) |
Freak Poster Join Date: Nov 2010 Location: nowshera kpk pakistan
Member: 1450507 Status: Offline Sonork: 100.1603096 Thanks Meter: 49 | ince the international version of Huawei Honor 3C (H30-U10) comes with a locked bootloader, it is always recommended that anyone who wants to try out the Chinese KitKat firmware on their device should get their phone’s bootloader unlocked first to avoid soft-bricking. In this article I’ve put together a concise step-by-step tutorial on how to safely unlock the bootloader using the good ol’ SP Flash Tool. Honor 3C Recovery How to Unlock Honor 3C’s Bootloader 1.Prerequisites *International H30-U10 variant of Honor 3C *Full dump/backup of current system created using MTKdroid Tools *Stock Android 4.2.x Jelly Bean firmware *A USB cable and latest MTK drivers installed on PC link hear DriverAutoInstaller_v1.1236.00 Handset_WinDriver_1.00.00.31 Disclaimer: This technique has been fully tested by developers on Honor 3C but I still won’t be held responsible for bricked/malfunctioned devices at any point during or after the process. You proceed entirely at your own risk! 2. Procedure *Install the required MTK USB drivers you downloaded earlier. *Download SP Flash Tool.zip https://mega.nz/#!O8EgEaiD!AfYhT38ut...pqv959KwhOiMon your PC and extract its contents. *Next, download “Honor3CBootUnlock.zip” “https://mega.nz/#!GolQwSqL!H2WzMzQ8m...2XNdU3-5L1RPg” on the computer and unzip it too. *Execute “FlashTool.exe” on the PC. *Click “Scatter-loading” and select “MT6582_Android_scatter” file placed inside “Honor3CBootUnlock” folder. *After that, click Window menu and check “Write Memory”. A new tab named Write Memory should appear. *In Write Memory tab, click Open Raw Data and select “preloader_huawei82_wet_jb5.bin”. *Set Memory Setting to “EMMC”, Beginning Address to “0x800” and Container Length to “0x1B0EC”. Finally click Write Memory button. *Go to Download tab and press the “Download” button. Make sure you’ve disconnected the USB cable. Check “DA DL All With Check Sum” option *A Download Warning message should pop up, click “Yes”. *Reconnect your phone in Meta mode by connecting it to the PC via USB cable and powering it on without its battery inserted. Wait for a few minutes until it gets completed. Flash TWRP Custom Recovery Flashing TWRP’s custom recovery on Honor 3C (and all other MTK devices) has become extremely easy thanks to Easy Magic TWRP Installer. Just download Easy Magic TWRP here Easy Magic TWRP Installer for MediaTek Devices ONLY (Developers ONLY) - xda-developers DevDB, execute the file and flash the recovery on your phone by following onscreen instructions. You’ll be good to go in no time! |
The Following 2 Users Say Thank You to sawed rashid For This Useful Post: |
05-15-2016, 10:11 | #28 (permalink) |
Insane Poster Join Date: Dec 2009 Location: Lahore Pakistan Age: 40
Member: 1174257 Status: Offline Sonork: 100.1658231 Thanks Meter: 8 | need firmware huawei honor 3c h30-t00 this model cpu mt6572 not mt6582 i am tri many firmware but not success Alps_H30_w216_td_znx_8g_f tri ALPS-H30-U10 tri note firmware not password protected thanks in Adwance sorry for bad english |
06-24-2016, 11:23 | #29 (permalink) | |
Junior Member Join Date: Jun 2016
Member: 2590376 Status: Offline Thanks Meter: 0 | Quote:
