Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
03-19-2018, 08:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2012
Member: 1792561 Status: Offline Thanks Meter: 78 | huawei Nexus 6p blink android logo need help huawei Nexus 6p blink android logo come and go again come and go. i try to hard reset vol-/power , go recovery but not came delete option it go Again android logo go and come. how to revive this phone? please help it show below: Code: BL:angler-03.79 Baseband: angler-03.85 Product/Variant:ANGLER-ROW-VN1 Serial Number:CVH7XXXXXXXXXXX CPU:MSM8994 0x20001 eMMC:64GB Toshiba DRAM:3072MB HYNIX LPDDR4 Consul:NULL Battery OK Divice is LOCKED. Qfuse Status:ENABLED. Off-mode-charge:ENABLED. Download Mode:DISABLED. Connect USB Data Cable |
03-19-2018, 14:14 | #4 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Joined Infinity(dec2018)
Member: 1647864 Status: Offline Thanks Meter: 80 | Welcome... Go http://forum.gsmhosting.com/vbb/f929...overy-2006946/ And follow the instructions carefully |
The Following User Says Thank You to bhalaygilani For This Useful Post: |
03-19-2018, 14:15 | #5 (permalink) |
03-22-2018, 06:12 | #6 (permalink) | |
Member: 1792561 Status: Offline Thanks Meter: 78 | Quote:
i read there carefully. Flashing Procedure: Code: * Goto Settings /About Phone/ Tap on Build numbers 7 to 9 times until Developer mode is enabled. * Goto Developer Option enable OEM Unlocking & Usb Debugging Turn off Your Device Hold vol Dwn + Pwr Button to Get into fastboot Mode nd run Below given command to unlock your Bootloader. | |
03-23-2018, 15:23 | #7 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1147875 Status: Offline Thanks Meter: 3 | remove the back cover, heat the board in the area of the processor, the phone must boot. You have time to go to the developer's menu and turn on the factory unlock. Next, you need to flash the kernel modified to work with 4 cores |
