Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 07-17-2019, 20:10   #1 (permalink)
Member: 2085676
Thanks Meter: 299
Huawei P20 Lite 9.0 New FRP Lock Problem Need Solution
hello new hauwei p20 lite 9.1 frp problam \
Old 07-17-2019, 20:48   #2 (permalink)
Member: 15156
Thanks Meter: 73
Testpoint is the only way
Old 07-23-2019, 15:53   #3 (permalink)
Member: 2771307
Thanks Meter: 772
You tested this solution not work for you ?
http://forum.gsmhosting.com/vbb/f929...ethod-2645701/
Old 07-23-2019, 17:57   #4 (permalink)
Member: 2085676
Thanks Meter: 299
try but not working this ....
Old 09-01-2019, 09:28   #5 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 292
Easy .
Old 09-01-2019, 15:58   #6 (permalink)
Member: 2085676
Thanks Meter: 299
Easy .
means ?
Old 09-02-2019, 06:47   #7 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 292
bro frp is easy to remove but huawei id is,,,,,,,, **************
Old 09-02-2019, 14:07   #8 (permalink)
Member: 2796172
Thanks Meter: 42
Can you please provide solution, instead of this bs?
Old 09-02-2019, 22:57   #9 (permalink)
alexmkdMAFIA's Avatar
Member: 212574
Sonork: 100.1580063
Thanks Meter: 63
testpoint or frp key,that is your solution
Old 09-03-2019, 11:10   #10 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 292
bro why you thing its very hard its like 1 2 3, that,s it. just make tp and reset it with any tool etc
Old 09-03-2019, 16:40   #11 (permalink)
Member: 2715751
Thanks Meter: 242
Huawei P20 Lite ANE-LX1 Reset FRP is successfully reseted
Old 09-03-2019, 17:23   #12 (permalink)
Member: 2085676
Thanks Meter: 299
need bypass not use any box ...
Old 09-04-2019, 18:53   #13 (permalink)
Member: 2085676
Thanks Meter: 299
found . very easy 1st format after on safe mode
Old 09-09-2019, 00:28   #14 (permalink)
Member: 2406539
Thanks Meter: 101
huawei mate 20 lite also known as sne-lx1, keypad not working in recovery mode,
trying to remove passcode lock in recovery mode, when select factory reset option, keypad doesn't work, can't type 'yes' to reset the phone.. any solution..?
The Following User Says Thank You to TMAC1122 For This Useful Post:
Page generated in 0.19021 seconds with 9 queries
