Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
09-19-2019, 10:29 | #2 (permalink) |
Junior Member Join Date: Oct 2010 Location: ksa
Member: 1420889 Status: Offline Thanks Meter: 0 | Huawei P30 Lite new Frp 9.1 solution need !! Huawei P30 Lite 9.0.1 New FRP Lock Problem Need Solution No work Emergency Call No work secrets code No work sim Help hello new hauwei P30 lite 9.1 frp problam |
09-29-2019, 08:35 | #6 (permalink) |
Freak Poster Join Date: Mar 2015 Location: New Delhi Age: 28
Member: 2355125 Status: Offline Thanks Meter: 52 | Try These Manual Methods Huawei P30 lite MAR-LX1A. Remove Google Account,Bypass FRP ALL HUAWEI 2019 EMUI 9.0.1/9.0 Pie FRP/Google Lock Bypass | Latest Call Method | NO CODE NO TALKBACK Post Results Best regards Sagar Jaiswal Press Thanks if Helped |
The Following User Says Thank You to sagarjais For This Useful Post: |
10-08-2019, 18:12 | #14 (permalink) |
Junior Member Join Date: Nov 2010 Location: tunisia
Member: 1439198 Status: Offline Sonork: 22311495 Thanks Meter: 4 | same problem with test point --------- 2019-10-08 18:08:09 --------- SigmaKey 2.33.07b3 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM336), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 06/11/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 970 (v2) Sending boot...Failed Last edited by by-slimanto; 10-08-2019 at 18:21. |
The Following 2 Users Say Thank You to by-slimanto For This Useful Post: |
10-16-2019, 09:04 | #15 (permalink) |
Major Poster Join Date: Feb 2017
Member: 2680038 Status: Offline Thanks Meter: 10 | i disagree, just need the right firmware for the device to boot into safe mode. try firmware 9.1.0.215. once flash boot phone into recovery mode then hard reset device and boot into safe mode. once phone boot up you should be able to go into setting reset all setting restart phone then factory reset device from settings menu, FRP done. |
