Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
12-02-2014, 09:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | Huawei p6-u06 not able to flash with sd card my huawei ascend p6 phone don't boot up and i cant reset the phone went i re set formatting/cache..... data wipe complete. E :failed to mount /cache (invalid argument) E :failed to mount/data(invalid argument) as shown in the picture attached Can any help to find me a solution for this? |
12-02-2014, 10:26 | #2 (permalink) |
Member: 593876 Status: Offline Thanks Meter: 302 | I try this method but not response go to recovery mode 5.1 Force upgrade Step 1. A MICRO SD card of 2GB or more should be available. The MICRO SD card made by *******, Kingstone, or Kingmax is recommended. Step 2. Format the MICRO SD card (This operation is optional). Step 3. Make sure that there is an UPDATE.APP under the dload. Copy the Main package of dload in PC to dload of SD card. Step 4. Make sure your handset is power off. Insert the MICRO SD card into the handset. Pressing the VOLUME UP key and VOLUME DOWN key, then press the POWER key to power on the phone, and VOLUME UP key and VOLUME DOWN key should be pressed more than 3 seconds, then enter the Software |
12-02-2014, 17:56 | #3 (permalink) | |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | Quote:
The Following User Says Thank You to Braycel For This Useful Post: |
