Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
07-31-2017, 21:49 | #10 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Tanzania
Member: 2239923 Status: Offline Thanks Meter: 48 | Huawei y530 update very simply huawei y530 update very simply processing 1. Use sd card original 2. Copy dload folder and in side is update.app any version but same model number like y530. After that is firmware update is different update processing was cancel and auto phone reboot to recovery for this step is important because its give you option for read information firmware by using recovery mode on ir-key suite go on general and read information after that you have see full information and update according to that information thank |
The Following User Says Thank You to Hussein70 For This Useful Post: |
09-22-2017, 07:38 | #11 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Me also I have the same problem, stuck in fastboot mode, tried to flash via Sd Card gives error can't flash !!!! |
The Following User Says Thank You to Fragga For This Useful Post: |
09-24-2017, 10:19 | #12 (permalink) | |
Member: 2239923 Status: Offline Thanks Meter: 48 | Quote:
USE THIS WAY 100% huawei y530 update very simply processing 1. Use sd card original 2. Copy dload folder and in side is update.app any version but same model number like y530. After that is firmware update is different update processing was cancel and auto phone reboot to recovery for this step is important because its give you option for read information firmware by using recovery mode on ir-key suite go on general and read information after that you have see full information and update according to that information thank | |
09-25-2017, 18:18 | #13 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | u need to know what is ur device's build no , so u can flash it with the same firmware ,to prevent errors during the flash process |
The Following User Says Thank You to xx0o0xx1 For This Useful Post: |
12-16-2017, 14:40 | #15 (permalink) |
Freak Poster Join Date: Oct 2015 Location: Pakistan Age: 36
Member: 2477331 Status: Offline Sonork: 100.1676088 Thanks Meter: 29 | Y530-U00 stuck in fastboot mode i try to update via sd card but not success i think this is a Emmc problam. |
The Following User Says Thank You to Bajwa786 For This Useful Post: |
