Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 10-24-2018, 22:05   #1 (permalink)
Member: 2574517
LYA-L29 Mate 20 Pro retail demo mode how to remove
hi ,is any way to remove retail demo from LYA-L29 ?
Old 02-28-2019, 11:32   #2 (permalink)
Lvrajal's Avatar
Member: 1979249
Thanks Meter: 53
Any solutions to this?
Old 03-04-2019, 07:21   #3 (permalink)
KATOUE's Avatar
Member: 9732
Thanks Meter: 20
Hi
Try to read about FunkyHuawei
Old 03-21-2019, 03:09   #4 (permalink)
Member: 1822938
Sonork: 100.1656339
Thanks Meter: 55
try HSTool on XDA
Old 03-29-2019, 12:37   #5 (permalink)
Member: 1822958
Thanks Meter: 33
it depends, there isnt a reliable method but ive been working on it, i bought a solution from one guy, it had potential but didnt actually work as it seemed to need an unlocked bootloader, i emailed him and he said "downgrade and ill tell you how" failing to mention what to downgrade to or how to do it.
so i began researching and messing about, somehow between octoplus and DCunlocker i actually managed to get te device to PHONE unlocked in fastboot but as the oem unlock option still wasnt available i still couldnt use it.
so i worked on downgrading, i have attempted flashing via SD, in update mode, fastboot mode and tried the HStool method, initially it says the device isnt supported, you can add support by editing an xml file in appdata but then you simply get "recovery packages not available for this device" i havent yet found a way to flash it, even the correct C652 package wont flash via any method ive tried
after a while i decided to try a standard OTA update to the latest version from the 108D i was on in the hope it would allow the OEM unlock button to work but all it did was put the bootloader back to PHONE Locked
if youre not too bothered about a few remnants of the demo and can live with being stuck on whatever version the hw demo unit gets you can disable and uninstall the demo software fairly easily but it will come back on a factory reset and youll still have a banner in the notifications saying retail demo but otherwise its totally usable
if i make any further progress ill report back
The Following 2 Users Say Thank You to stabbinbaz For This Useful Post:
Old 03-31-2019, 16:27   #6 (permalink)
plentong's Avatar
Member: 44095
Thanks Meter: 34
If can unlock bootloader, it possible to change oeminfo or not?
Old 03-31-2019, 22:18   #7 (permalink)
Member: 17415
Thanks Meter: 12
to enable “OEM unlock” device needs to be connected to internet, also once you have an unlocked bootloader you can flash custom recovery and Rom via it.
Sent from my iPhone using Tapatalk
Old 03-31-2019, 22:59   #8 (permalink)
Member: 877421
Sonork: halim
Thanks Meter: 43
im unlocked bootloader and roote phone and edit oeminfo , after reboot phone make hard reset and demo back
Old 04-01-2019, 08:37   #9 (permalink)
Member: 1822958
Thanks Meter: 33
i think the next stage youd need to do is to flash the xloader partition only in fastboot from a clean C432 (or whichever non demo firmware you are flashing) after that flash the rest of the firmware from a USB pen in forced upgrade mode
how did you manage to enable OEM unlock option in the menu though?
Old 05-13-2019, 13:25   #10 (permalink)
Member: 1973611
Thanks Meter: 3
friend you can give us oem info???
Old 05-15-2019, 09:26   #11 (permalink)
Member: 1822958
Thanks Meter: 33
here you go
https://drive.google.com/open?id=1BP...cxFJ5kGOFADcQ3
The Following User Says Thank You to stabbinbaz For This Useful Post:
Old 05-15-2019, 14:39   #12 (permalink)
Member: 1973611
Thanks Meter: 3
thank you friend, but DCPhoenix does not accept these files, nor does it accept the oeminfo file from the factory board
Old Yesterday, 15:23   #13 (permalink)
Member: 1822958
Thanks Meter: 33
you CANNOT flash oeminfo with DCPhoenix or anything else via fastboot. the ONLY way is if you already have an unlocked bootloader and root. that is a twrp (or basically dd) backup of the oeminfo partition
Page generated in 0.17259 seconds with 7 queries
