Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
08-01-2019, 08:59 | #1 (permalink) |
Junior Member Join Date: Jun 2018
Member: 2844140 Status: Offline Thanks Meter: 2 | How To Root Android - A Simple Way To Unlock Huawei Y6 2018 Unlocking Bootloader Some devices can be easily unlocked connect your device to a PC after pressing a specifc button combination that has been recommended by your device manufacturer. But you cannot use the same procedure for all the Andriod devices as each device has its specific way to be unlocked. Huawei, Motorola, and HTC are the toughest devices that cannot be unlocked easily. Currently. You need official code from the device manufacturer to unlock these smartphones and the code needs to apply the device using ADB and Fastboot commands. If your device manufacturer does not support you, you have to choose an unofficial way to unlock it. When it comes to Huawei smartphones, currently, Hauwei does not provide unlocking coed officially for its devices, How to unlock is more important than How to root as unlocking is the first which help you to gain root access successfully without ends up with a bricked device How To Unlock Huawei Y6 2018 As you know, Hauwei does not provide Bootloader unlock code anymore and you need to use another way to get your BL unlocking code. Currently, DC-unlocker program plays a special role in unlocking smartphones and router being the first in its kind of program. But you cannot have the programme for free as it should be purchased through its website. After getting the BL code, follow these steps Install HiSuite on your computer Install Minimal adb and fastboot on your computer Next, connect your device to the computer Enable USB Debugging and OEM Unlock on your device Open a command window and type adb devices and accept the message display on your device screen, also check if your device is recognized Next, type adb reboot bootloader Then, type fastboot devices and see if your device is recognized Finally, type fastboot oem unlock (bl unlock code) to unlock your device |
