09-22-2019, 20:31 | #6 (permalink) | |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
hua generic/tools/hua lang service/press enable all language method 1,2,3/connect usb to phone/need root and usb debugging | |
The Following User Says Thank You to Hua Supporter For This Useful Post: |
10-01-2019, 08:19 | #7 (permalink) | |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | Quote:
Code: 2019-21-09 - 11.03.07 : For Android 2.x.x: 2019-21-09 - 11.03.07 : 1- Turn-on the Phone Goto 'Settings > Application > Development' 2019-21-09 - 11.03.07 : 2- And Check 'Usb Debugging' Then Connect Usb Cable To Phone 2019-21-09 - 11.03.07 : 2019-21-09 - 11.03.07 : For Android 4.x.x and Above: 2019-21-09 - 11.03.07 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2019-21-09 - 11.03.07 : 2- Return to General Tab Tap on Developer Options 2019-21-09 - 11.03.07 : 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone 2019-21-09 - 11.03.07 : 2019-21-09 - 11.03.07 : IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME! 2019-21-09 - 11.03.12 : Prepairing ...OK 2019-21-09 - 11.03.30 : Device Found! 2019-21-09 - 11.03.30 : Adding Persian Language... OK 2019-21-09 - 11.03.32 : Rebooting to Normal Mode... OK 2019-21-09 - 11.03.32 : Now going to Setting Menu and Select Persian Language. 2019-21-09 - 11.03.32 : Operation Completed 2019-21-09 - 11.03.32 : Operation Time: 00:00:25 2019-21-09 - 11.12.19 : For Android 2.x.x: 2019-21-09 - 11.12.19 : 1- Turn-on the Phone Goto 'Settings > Application > Development' 2019-21-09 - 11.12.19 : 2- And Check 'Usb Debugging' Then Connect Usb Cable To Phone 2019-21-09 - 11.12.19 : 2019-21-09 - 11.12.19 : For Android 4.x.x and Above: 2019-21-09 - 11.12.19 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2019-21-09 - 11.12.19 : 2- Return to General Tab Tap on Developer Options 2019-21-09 - 11.12.19 : 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone 2019-21-09 - 11.12.19 : 2019-21-09 - 11.12.19 : IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME! 2019-21-09 - 11.12.19 : Waiting For Device... OK[WinUSB] 2019-21-09 - 11.12.21 : Please Tap on 'OK' in 'Allow Usb Debugging;' Pop-up on Device Screen! 2019-21-09 - 11.12.28 : Device Status: [ONLINE] 2019-21-09 - 11.12.28 : Model : GT-N5100 2019-21-09 - 11.12.28 : Manufacturer : samsung 2019-21-09 - 11.12.29 : Serial No. : 4dfc3d39868641fb 2019-21-09 - 11.12.29 : BaseBand Version : N5100DXDNG1 2019-21-09 - 11.12.29 : SW Version : KOT49H.N5100XXDNH2 2019-21-09 - 11.12.29 : Custom Version : 2019-21-09 - 11.12.29 : Android Version : 4.4.2 [KOT49H ] 2019-21-09 - 11.12.30 : Built Date : Thu Aug 14 19:36:11 KST 2014 2019-21-09 - 11.12.30 : Stopping ADB Service... OK 2019-21-09 - 11.12.30 : Operation Time: 00:00:10 2019-21-09 - 11.13.40 : For Android 2.x.x: 2019-21-09 - 11.13.40 : 1- Turn-on the Phone Goto 'Settings > Application > Development' 2019-21-09 - 11.13.40 : 2- And Check 'Usb Debugging' Then Connect Usb Cable To Phone 2019-21-09 - 11.13.40 : 2019-21-09 - 11.13.40 : For Android 4.x.x and Above: 2019-21-09 - 11.13.40 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2019-21-09 - 11.13.40 : 2- Return to General Tab Tap on Developer Options 2019-21-09 - 11.13.40 : 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone 2019-21-09 - 11.13.40 : 2019-21-09 - 11.13.40 : IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME! 2019-21-09 - 11.13.45 : Prepairing ...OK 2019-21-09 - 11.13.46 : Device Found! 2019-21-09 - 11.13.54 : Prepairing... OK 2019-21-09 - 11.13.56 : Reconfig Device... OK 2019-21-09 - 11.13.57 : Adding Persian Language... OK 2019-21-09 - 11.14.03 : Finalizing... OK 2019-21-09 - 11.14.03 : Operation Completed 2019-21-09 - 11.14.03 : Operation Time: 00:00:22 2019-21-09 - 11.15.22 : For Android 2.x.x: 2019-21-09 - 11.15.22 : 1- Turn-on the Phone Goto 'Settings > Application > Development' 2019-21-09 - 11.15.22 : 2- And Check 'Usb Debugging' Then Connect Usb Cable To Phone 2019-21-09 - 11.15.22 : 2019-21-09 - 11.15.22 : For Android 4.x.x and Above: 2019-21-09 - 11.15.22 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2019-21-09 - 11.15.22 : 2- Return to General Tab Tap on Developer Options 2019-21-09 - 11.15.22 : 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone 2019-21-09 - 11.15.22 : 2019-21-09 - 11.15.22 : IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME! 2019-21-09 - 11.15.27 : Prepairing ...OK 2019-21-09 - 11.15.27 : Device Found! 2019-21-09 - 11.15.28 : Adding Persian Language... OK 2019-21-09 - 11.15.30 : Rebooting to Normal Mode... OK 2019-21-09 - 11.15.30 : Now going to Setting Menu and Select Persian Language. 2019-21-09 - 11.15.30 : Operation Completed 2019-21-09 - 11.15.30 : Operation Time: 00:00:08 2019-21-09 - 11.23.35 : For Android 2.x.x: 2019-21-09 - 11.23.35 : 1- Turn-on the Phone Goto 'Settings > Application > Development' 2019-21-09 - 11.23.35 : 2- And Check 'Usb Debugging' Then Connect Usb Cable To Phone 2019-21-09 - 11.23.35 : 2019-21-09 - 11.23.35 : For Android 4.x.x and Above: 2019-21-09 - 11.23.35 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2019-21-09 - 11.23.35 : 2- Return to General Tab Tap on Developer Options 2019-21-09 - 11.23.35 : 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone 2019-21-09 - 11.23.35 : 2019-21-09 - 11.23.35 : IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME! 2019-21-09 - 11.23.40 : Prepairing ...OK 2019-21-09 - 11.23.40 : Device Found! 2019-21-09 - 11.23.41 : Adding Persian Language... OK 2019-21-09 - 11.23.43 : Rebooting to Normal Mode... OK 2019-21-09 - 11.23.43 : Now going to Setting Menu and Select Persian Language. 2019-21-09 - 11.23.43 : Operation Completed 2019-21-09 - 11.23.43 : Operation Time: 00:00:08 all operation completed but nothing to my desired language adedddd | |
10-01-2019, 09:39 | #8 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | why cannot read english?!!! http://forum.gsmhosting.com/vbb/13831829-post6.html method1,2,.... http://forum.gsmhosting.com/vbb/f930...-done-2492189/ |
