Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA Box
Old 10-20-2017, 14:10   #1 (permalink)
Member: 2506803
Sonork: 100.1671068
Thanks Meter: 19
HELP, After Reset my Account to Redmi note 4x global reboots
Searching for Device... OK
Prepairing Device on [Qualcomm HS-USB QDLoader 9008 (COM76)]... OK
Waiting for Phone ACK... OK
Serial Number: 62051E6E
CPU ID: 000460E100000000 | Type: MSM8953 Snapdragon 625
SBL Ver: 00000000
OEM Key(PK): 57158EAF1814D78FD2B3105ECE4DB18A817A08AC664A5782A9 25F3FF8403D39A
Changing Mode to SAHARA... OK
Prepairing... OK -> [0000000D][00000000:00000034]
Sending Loader... OK
Resetting... OK
Waiting for Loader Response...OK
Memory Type: eMMC
Platform: 8953
Parameters Initialized.
Phone Booting DONE.
Retriving Partition Table... OK
Setting TIMEOUTS... OK
Removing Xiaomi Account... OK
Rebooting to Normal Mode... OK
Connection terminated.
HELP, After Reset my Account to Redmi note 4x global (2016102) reboots and does not get to enter system and flashee and continues with the problems
PLEASE HELP
Old 10-20-2017, 15:02   #2 (permalink)
Hua Supporter's Avatar
Member: 2179353
Thanks Meter: 17,022
Your rom is not stock(china or developer rom)
Please write global stock rom for reset mi account
http://forum.gsmhosting.com/vbb/f930...wares-2267237/
http://forum.gsmhosting.com/vbb/12613412-post2.html
Old 10-20-2017, 15:24   #3 (permalink)
Member: 2506803
Sonork: 100.1671068
Thanks Meter: 19
I have already flashed with these 2 firmware and still no result continues with the problem that is restarted
help some firmware that could facilitate me to solve my problem or another solution
And thanks for responding
mido_global_images_7.9.15_20170915.0000.00_7.0_glo bal_3ae05ce954
mido_global_images_V8.5.8.0.NCFMIED_20170916.0000. 00_7.0_global_4e70bd1572
Old 10-20-2017, 15:29   #4 (permalink)
Member: 2600625
Sonork: aly_alumni_ptc
Thanks Meter: 58
same with me..... i reflash then my set gone normal.....
Old 10-20-2017, 15:35   #5 (permalink)
Member: 2179353
Download fastboot stock rom and write by hmi or mi flasher
Please wait 15 min after power on the phone
Old 10-20-2017, 16:57   #6 (permalink)
Member: 2506803
Sonork: 100.1671068
Thanks Meter: 19
I still stick with the problem and flashea with my flash and HUA Xiaomi Tool and without result
Already wait 20min to work normally after flashing and continue with the reboot problem
https://www.4shared.com/photo/_Aqjwo...6_online.html?
Old 10-20-2017, 17:50   #7 (permalink)
Member: 2179353
http://forum.gsmhosting.com/vbb/12741746-post5.html
Try remove battery and connect test point for flash by hmi(9008 mode)
Old 10-20-2017, 18:27   #8 (permalink)
Member: 2506803
Sonork: 100.1671068
Thanks Meter: 19
SBL Ver: 00000000
Resetting... OK
Memory Type: eMMC
Platform: 8953
Phone Booting DONE.
Load Files from: C:\Users\AlexanderPC7\Downloads\mido_global_images _7.9.15_20170915.0000.00_7.0_global_3ae05ce954\mid o_global_images_7.9.15_20170915.0000.00_7.0_global \images\
Flashing File 'NON-HLOS.bin' as Partition 'modem'... OK
Flashing File 'sbl1.mbn' as Partition 'sbl1'... OK
Flashing File 'sbl1.mbn' as Partition 'sbl1bak'... OK
Flashing File 'rpm.mbn' as Partition 'rpm'... OK
Flashing File 'rpm.mbn' as Partition 'rpmbak'... OK
Flashing File 'tz.mbn' as Partition 'tz'... OK
Flashing File 'tz.mbn' as Partition 'tzbak'... OK
Flashing File 'devcfg.mbn' as Partition 'devcfg'... OK
Flashing File 'devcfg.mbn' as Partition 'devcfgbak'... OK
Flashing File 'adspso.bin' as Partition 'dsp'... OK
Flashing File 'fs_image.tar.gz.mbn.img' as Partition 'fsg'... OK
Flashing File 'sec.dat' as Partition 'sec'... OK
Flashing File 'splash.img' as Partition 'splash'... OK
Flashing File 'emmc_appsboot.mbn' as Partition 'aboot'... OK
Flashing File 'emmc_appsboot.mbn' as Partition 'abootbak'... OK
Flashing File 'boot.img' as Partition 'boot'... OK
Flashing File 'recovery.img' as Partition 'recovery'... OK
Flashing File 'system.img' as Partition 'system'... OK
Flashing File 'cache.img' as Partition 'cache'... OK
Flashing File 'lksecapp.mbn' as Partition 'lksecapp'... OK
Flashing File 'lksecapp.mbn' as Partition 'lksecappbak'... OK
Flashing File 'cmnlib.mbn' as Partition 'cmnlib'... OK
Flashing File 'cmnlib.mbn' as Partition 'cmnlibbak'... OK
Flashing File 'cmnlib64.mbn' as Partition 'cmnlib64'... OK
Flashing File 'cmnlib64.mbn' as Partition 'cmnlib64bak'... OK
Flashing File 'keymaster.mbn' as Partition 'keymaster'... OK
Flashing File 'keymaster.mbn' as Partition 'keymasterbak'... OK
Flashing File 'cust.img' as Partition 'cust'... OK
Flashing File 'userdata.img' as Partition 'userdata'... OK
Flashing File 'gpt_main0.bin' as Partition 'PrimaryGPT'... OK
Flashing File 'gpt_backup0.bin' as Partition 'BackupGPT'... OK
Patching DISK Offset: '40' Size: '8' Start: '14' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update last partition 49 'userdata' with actual size in Primary Header.'... OK
Patching DISK Offset: '40' Size: '8' Start: 'NUM_DISK_SECTORS-21.' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update last partition 49 'userdata' with actual size in Backup Header.'... OK
Patching DISK Offset: '48' Size: '8' Start: '1' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update Primary Header with LastUseableLBA.'... OK
Patching DISK Offset: '48' Size: '8' Start: 'NUM_DISK_SECTORS-1.' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update Backup Header with LastUseableLBA.'... OK
Patching DISK Offset: '32' Size: '8' Start: '1' Value: 'NUM_DISK_SECTORS-1.' Comment: 'Update Primary Header with BackupGPT Header Location.'... OK
Patching DISK Offset: '24' Size: '8' Start: 'NUM_DISK_SECTORS-1.' Value: 'NUM_DISK_SECTORS-1.' Comment: 'Update Backup Header with CurrentLBA.'... OK
Patching DISK Offset: '72' Size: '8' Start: 'NUM_DISK_SECTORS-1' Value: 'NUM_DISK_SECTORS-33.' Comment: 'Update Backup Header with Partition Array Location.'... OK
Patching DISK Offset: '88' Size: '4' Start: '1' Value: 'CRC32(2,6656)' Comment: 'Update Primary Header with CRC of Partition Array.'... OK
Patching DISK Offset: '88' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: 'CRC32(NUM_DISK_SECTORS-33.,6656)' Comment: 'Update Backup Header with CRC of Partition Array.'... OK
Patching DISK Offset: '16' Size: '4' Start: '1' Value: '0' Comment: 'Zero Out Header CRC in Primary Header.'... OK
Patching DISK Offset: '16' Size: '4' Start: '1' Value: 'CRC32(1,92)' Comment: 'Update Primary Header with CRC of Primary Header.'... OK
Patching DISK Offset: '16' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: '0' Comment: 'Zero Out Header CRC in Backup Header.'... OK
Patching DISK Offset: '16' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: 'CRC32(NUM_DISK_SECTORS-1.,92)' Comment: 'Update Backup Header with CRC of Backup Header.'... OK
Operation Time: 00:05:48
Follow the problem and hope I'm missing some trick or extra solution that have under the sleeve colleagues of hua
and again thanks for watching my problem
Old 10-21-2017, 15:49   #9 (permalink)
Member: 2506803
Sonork: 100.1671068
Thanks Meter: 19
Anything new to solve my 4x note problem
Old 10-21-2017, 16:44   #10 (permalink)
Member: 2179353
You just need select correct rom for phone.
Page generated in 0.22461 seconds with 8 queries
