04-04-2016, 14:22 | #17 (permalink) |
No Life Poster Join Date: Jun 2011 Location: Kabul City Afghanistan Age: 38
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | thanks a lot great update you are the best team in the world what i was looking for that finally i got it from your team thanks in advance |
The Following 3 Users Say Thank You to abdulhaq_majroh For This Useful Post: |
04-05-2016, 08:09 | #23 (permalink) |
Freak Poster Join Date: Dec 2014 Location: bahrain
Member: 2308999 Status: Offline Sonork: 100.1657583 Thanks Meter: 34 | frp reset for all 2016 models and new security open side sync Connect phone Glaxy apps Install es file explorer Open file exploarer Connect otg cable Install samsung account remove.apk Open Dont reset Go to security Set pin code do not show notifictaion set Go to other security setting Trust agents Off smart lock off Device adminsitator android device manager Off Go to easy mode Slect easy mode Phone menu Easy mode off Go to about Usb dubing on oem unlock On Now reset phone |
The Following 2 Users Say Thank You to askdm7 For This Useful Post: |
04-05-2016, 17:04 | #24 (permalink) | |
Insane Poster Join Date: Oct 2015
Member: 2472075 Status: Offline Thanks Meter: 12 | Quote:
I have done all method step by step but no luck. frp lock not remove. plz sir give me A510FXXU1AOLB download firmware link. | |
04-05-2016, 17:16 | #25 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | after frp reset frp a510f same frp on what a next Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM16 Initialize Phone ... OK Prepairing... OK Reading PIT Data ...OK Analizing PIT Entries... OK Pit Entry Num: 27 Unocking FRP... OK Resetting... Operation Time: 00:00:07 |
04-05-2016, 17:50 | #26 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM98 Initialize Phone ... OK Prepairing... OK Reading PIT Data ...OK Analizing PIT Entries... OK Pit Entry Num: 27 Unocking FRP... OK Resetting... Operation Time: 00:00:07 install hua apk then try with hua but still frp try downgrade,..... how can remove? |
04-05-2016, 21:21 | #28 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Please read manual carefully before reset You can reset frp when oem is disable and need downgrade to my files if have problem for enable http://forum.gsmhosting.com/vbb/11738919-post33.html |
04-05-2016, 22:29 | #30 (permalink) | ||||
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
read here before reset frp :-) http://forum.gsmhosting.com/vbb/11738926-post28.html Quote:
http://forum.gsmhosting.com/vbb/f930...-file-2071384/ http://forum.gsmhosting.com/vbb/f930...-file-2071389/ | ||||
The Following 4 Users Say Thank You to Hua Supporter For This Useful Post: |
