12-04-2017, 19:56 | #1 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | How to select manual loader for hqt tool? Warning: PLEASE CHECK CHIPSET INFO BEFORE SELECT FILE !!!! EXAMPLE : Qualcomm_Factory_Loader_MSM8909_Lite.mbn LOADER FILES PATCH : C:\AHT2\DATA\Qualcomm's MBN File |
The Following User Says Thank You to Hua Supporter For This Useful Post: |
12-04-2017, 20:02 | #2 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | SELECT MANUALLY LOADER IF WANT USE SEPCIAL FILES Warning: PLEASE CHECK CHIPSET INFO BEFORE SELECT FILE !!!! EXAMPLE : Qualcomm_Factory_Loader_MSM8909_Lite.mbn LOADER FILES PATCH : C:\AHT2\DATA\Qualcomm's MBN File Important note ENABLE USE INTERNAL LOADER FOR XML AND IGNORE PACKAGE LOADER FOR SPECIAL FILES IF WANT AUTOMATIC LOADER ON HQT |
12-04-2017, 20:03 | #3 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Important note Prepairing SPEC. File... OK.OK Package Dont Have Loader! Searching for Device... OK Prepairing Device on [Qualcomm HS-USB QDLoader 9008 (COM20)]... OK Waiting for Phone ACK... Fail! Connection terminated. Operation Time: 00:00:00 UNISTALL DRIVER AND INSTALL AGAIN FROM THIS PATH C:\AHT2\Driver |
12-04-2017, 20:04 | #4 (permalink) | |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Important note Quote:
12-04-2017, 20:05 | #5 (permalink) | |
12-04-2017, 20:09 | #6 (permalink) | |
-PHONE IS NOT SUPPORTED WITH AUTOMATIC LOADER -SELECT MANUALLY LOADER | |
12-04-2017, 20:10 | #7 (permalink) | |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
12-05-2017, 11:02 | #8 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | WHERE CAN FIND FIREHOSE LOADERS? --C:\AHT2\DATA\Qualcomm's MBN File --SOME NEW LOADERS ADD ON THIS VERSION -Inside the STOCK files OR UNBIRCK FILES Last edited by Hua Supporter; 12-05-2017 at 11:17. |
