*********HUA BOX AND FRP TOOL and UBTOOL MANUALS(step by step)*********** HOW TO DIRECT UNLOCK MTK PHONES? -NEED ROOT AND USB DEBUGGING -PRESS ON BUTTON FIRST THEN INSERT USB CABLE TO PHONE http://uupload.ir/files/hpfa_1.png HOW TO READ UNLOCK CODE MTK PHONES? -NEED ROOT AND USB DEBUGGING -PRESS ON BUTTON FIRST THEN INSERT USB CABLE TO PHONE http://uupload.ir/files/dh38_2.png |
HOW TO REPAIR IMEI MTK PHONES? -NEED ROOT AND USB DEBUGGING -PRESS ON BUTTON FIRST THEN INSERT USB CABLE TO PHONE WE HAVE 8 METHOD FOR REPAIR IMEI BY ADB MODE and 1 METHOD BY META MODE MOST METHODS ARE PERMANENT PERMANENT FIX IS FOR Serial No. : 0123456789ABCDEF(NEED REPAIR BY ASAN METHOD FIRST AND THEN USE PERMANENT FIX METHOD) http://uupload.ir/files/tqr4_3.png |
HOW TO REPAIR INVALID IMEI BY RII FILE? -NEED ROOT AND USB DEBUGGING AND BUSYBOX FOR REPAIR -PRESS ON BUTTON FIRST THEN INSERT USB CABLE TO PHONE -RII FILE ARE ON HUA TEAM TELEGRAM CHANNAL http://uupload.ir/files/xg2e_4.png |
HOW TO REPAIR INVALID IMEI WITHOUT SELECT FILE? -NEED ROOT AND USB DEBUGGING AND BUSYBOX FOR REPAIR -PRESS ON BUTTON FIRST THEN INSERT USB CABLE TO PHONE -NOT SUPPORTED ALL MTK CPU http://uupload.ir/files/bcds_5.png |
HOW TO READ AND WRITE NVRAM.TAR OR NVRAM.BIN? -NEED ROOT AND USB DEBUGGING AND BUSYBOX FOR REPAIR -PRESS ON BUTTON FIRST THEN INSERT USB CABLE TO PHONE -YOU CAN WRITE NVRAM BIN+TAR ON PHONE BY THIS METHOD http://uupload.ir/files/vet3_6.png |
HOW TO REPAIR IMEI MOST SPD PHONES WITHOUT ROOT? -NEED CONNECT PHONE TO DIAG MODE(DRIVER) -PRESS ON BUTTON FIRST THEN REMOVE BATTERY AND INSERT USB CABLE TO PHONE http://uupload.ir/files/bghq_7.png |
HOW TO UNLOCK SAMSUNG EXYNOS PHONES WITHOUT ROOT? -NO NEED ROOT -JUST 11 SEC -CONNECT PHONE TO MODEM MODE -CHECK MODEM PORT ON DEVICE MANANGER BEFORE PRESS UNLOCK -CHECK MODEM MODE ON PHONE SETTING IF NOT SHOW ON PC http://uupload.ir/files/3tcp_8.png |
HOW TO UNLOCK SAMSUNG QUALCOMM PHONES WITHOUT ROOT? -NO NEED ROOT -JUST 3 SEC -CONNECT PHONE TO DIAG MODE(*#0808# OR ENABLE DIAG PORT BUTTONT ON HUA) -CHECK DIAG PORT ON DEVICE MANANGER BEFORE PRESS UNLOCK -CHECK DIAG MODE(RNDIS+DM+MODEM)ON PHONE SETTING IF NOT SHOW ON PC http://uupload.ir/files/edj0_9.png |
HOW TO UNLOCK FRP/REACTIVATION/SAM ACCOUNT SAMSUNG QUALCOMM 2015/2016 PHONES BY DOWNLOAD MODE? -CONNECT PHONE TO DOWNLOAD MODE/ODIN MODE http://uupload.ir/files/w4i5_10.png RESET FRP QUALCOMM NEW LIST MODELS (1).txt |
HOW TO UNLOCK FRP/REACTIVATION/SAM ACCOUNT SAMSUNG EXYNOS 2015/2016 PHONES BY DOWNLOAD MODE? -CONNECT PHONE TO DOWNLOAD MODE/ODIN MODE http://uupload.ir/files/wepo_11.png EXYNOS FRP LIST MODELS.txt |
HOW TO RESET FRP LG QUALCOMM PHOMES WITHOUT ROOT? DRIVER IS Important FOR RESET With Power-off Phone Hold Volume+ then Connect USB Cable to Phone Install needed drivers Select LG Usb Serial Port http://uupload.ir/files/mqqy_12.png |
HOW TO REPAIR IMEI LG QUALCOMM PHONE WITHOUT ROOT? -JUST 3 SEC -DRIVER IS IMPORTANT FOR CONNECTION -NEED ENABLE DIAG PORT BEFORE REPAIR -NEED SELECT DIAG PORT ON PORT SETTING -USE ENABLE DIAG PORT ON HUA/LG TAB OR ENTER CODE FOR DIAG VIDEO http://uupload.ir/files/nvxz_13.png ---------------------- Please, make sure that You perform these steps:To connect the phone in Normal Mode, do the next: Select "Charge Phone" in "USB PC Connection" menu. Type ##3424#, go to "Diag" menu and select "Enable". This menu is blocked by SPC/MSL. ---------------------------------- 277634#*# -> Port check Test -> set Enabled. Reconnect device. ----------------------- Select "tethering mode" after usb connection ----------------------- Just enable usb developer mode(adb) plug phone enter code: *#546368#*855# Then in meniu choose SVC Menu Then choose Port Check Test And must enable it. After all You can connect phone to PC by USB cable. Then must install drivers. -------------------------- Enable Diagnostic Port 1. 277634#*# or 3845#*# 2. Select Port Check Test 3. Enable Port Check Test Reconnect Mobile ----------------------- Please Type 277634#*# then find and set 'Port Check Test' to 'Enable', ---------------------------- use 3845#*505# OR *#546368#*505# --------------------------------- Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will apear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*631# *#546368#*631# --------------------------------- In case you can not get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. DIAG mode serial found. ------------------------------ Please, type ##3424# to get SPC / MSL / Service Code...OK Go to "Diag" menu and select "Enable" option. |
HOW TO UNLOCK LG QUALCOMM PHONE WITHOUT ROOT? -JUST 3 SEC -DRIVER IS IMPORTANT FOR CONNECTION -NEED ENABLE DIAG PORT BEFORE REPAIR -NEED SELECT DIAG PORT ON PORT SETTING -USE ENABLE DIAG PORT ON HUA/LG TAB OR ENTER CODE FOR DIAG VIDEO http://uupload.ir/files/4i25_14.png ---------------------- Please, make sure that You perform these steps:To connect the phone in Normal Mode, do the next: Select "Charge Phone" in "USB PC Connection" menu. Type ##3424#, go to "Diag" menu and select "Enable". This menu is blocked by SPC/MSL. ---------------------------------- 277634#*# -> Port check Test -> set Enabled. Reconnect device. ----------------------- Select "tethering mode" after usb connection ----------------------- Just enable usb developer mode(adb) plug phone enter code: *#546368#*855# Then in meniu choose SVC Menu Then choose Port Check Test And must enable it. After all You can connect phone to PC by USB cable. Then must install drivers. -------------------------- Enable Diagnostic Port 1. 277634#*# or 3845#*# 2. Select Port Check Test 3. Enable Port Check Test Reconnect Mobile ----------------------- Please Type 277634#*# then find and set 'Port Check Test' to 'Enable', ---------------------------- use 3845#*505# OR *#546368#*505# --------------------------------- Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will apear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*631# *#546368#*631# --------------------------------- In case you can not get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. DIAG mode serial found. ------------------------------ Please, type ##3424# to get SPC / MSL / Service Code...OK Go to "Diag" menu and select "Enable" option. |
HOW TO RESET SCREEN LOCK LG QUALCOMM PHONES WITHOUT ROOT ADN USB DEBUGGING? Remove Screen Lock Manual: - Connect Phone in 'Download Mode' For Doing that: with Power off Phone Hold Volume Up Button then Connect USB Cable to Phone - Install Need Driver if Windows Request - in Select Port Select 'LGE AndroidNet USB Serial Port' - Click on 'Remove Screen Lock' and Following rest Procedure --OLD METHOD IS FOR 5.X.X/6.X.X --NEW METHOD IS FOR 2017/2018 ENCRYPTED PHONES VIDEO http://uupload.ir/files/or7p_2018-06-16_23-10-31.jpg |
