01-02-2017, 21:53 | #31 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | -GENERIC METHOD -DONT HAVE LIST MODEL -NEED CONNECT PHONE TO FASTBOOT |
The Following 2 Users Say Thank You to Hua Supporter For This Useful Post: |
01-02-2017, 21:56 | #33 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | HOW TO READ AND WRITE FLASH BY ADB MODE? -NEED ROOT AND BUSYBOX -NEED FACTORY RESET AFTER WRITE 1) Make sure Your Device SD Ram has at least 1 GB Free Space 2) Make Sure your Phone has ROOT permission 3) Make Sure BusyBox application is already installed on phone Write Allwinner CPU Dump File Notes: 1) Make sure Your Device SD Ram has at least 2 GB Free Space 2) Make Sure your Phone has ROOT permission 3) Make Sure BusyBox application is already installed on phone 4) Copy 'system.tgz','data.tgz','bootloader.img','boot.img ','recovery.img' to your Phone's SD Card |
01-02-2017, 22:00 | #34 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | HOW TO READ UNLOCK BOOTLOADER CODE FOR HUAWEI PHONES? -NO NEED ROOT -NEED AUTHORIZE BY 1 CREDIT BY HDE TOOLS -NEED CONNECT PHONE TO MANUFACTOR MODE -NEED DB ADAPTER PORT FOR QUALCOMM PHONES -NEED PCUI PORT FOR HISILICON PHONES |
01-02-2017, 22:02 | #35 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | HOW TO REPAIR IMEI HUAWEI QUALCOMM PHONES? -NO NEED ROOT -NEED AUTHORIZ BY 1 CREDIT(HDE TOOL)FOR ENABLE DIAG PORT -NEED CONNECT PHONE TO MANUFACTOR MODE -NEED SELECT DB ADAPTER PORT FREE SOLUTION FOR AUTHORIZE WIHTOUT CREDIT FOR G630/G6/Y530 active diag.7z PASSWORD : 9130898005 Last edited by Hua Supporter; 03-15-2017 at 12:07. |
The Following 3 Users Say Thank You to Hua Supporter For This Useful Post: |
11-21-2017, 21:21 | #40 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | HUA FRP TOOL SAMSUNG MANUALS : DL MODE METHOD -QUALCOMM FRP LIST MODELS -EXYNOS FRP LIST MODELS -2015/2016 OLD AND NEW this method is for old phones same g531h/j700h/j500h/j700f and other models and need write reset frp file or sboot if show error |
11-21-2017, 21:23 | #41 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | HUA FRP TOOL SAMSUNG MANUALS : ADB MODE METHOD this operation works for the mentioned above devices with Android 6.x firmwares' versions and may not work for some phones’ S-boot. In this case try to write another firmware version or only S-boot from firmware and repeat the operation again. WRITE SPECIAL FILE OR COMBINATION OR ENABLE ADB FILE + RESET FRP BY HUA + WRITE FULL FIRMWARE |
01-02-2018, 12:48 | #42 (permalink) | |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
Press enable diag port then insert usb cable to phone apply usb deubgging and root done | |
01-02-2018, 12:48 | #43 (permalink) | |
