redmi note 4 SD factory flash done!!!
2018-19-07 - 11:39:48 : Stop Signal Detected!
2018-19-07 - 11:39:48 : Procedure Stopped By User Request
2018-19-07 - 11:39:48 : Connection terminated.
2018-19-07 - 11:39:48 : Operation Time: 00:00:08
2018-19-07 - 11:40:10 : Searching for Device... OK
2018-19-07 - 11:40:10 : Prepairing Device on [COM18-Qualcomm HS-USB QDLoader 9008 ]... OK
2018-19-07 - 11:40:10 : Waiting for Phone ACK... OK
2018-19-07 - 11:40:10 : Serial Number: F0042937
2018-19-07 - 11:40:10 : CPU ID: 000460E100000000 | Type: MSM8953 Snapdragon 625
2018-19-07 - 11:40:10 : SBL Ver: 00000000
2018-19-07 - 11:40:10 : OEM Key(PK): 57158EAF1814D78FD2B3105ECE4DB18A817A08AC664A5782A9 25F3FF8403D39A
2018-19-07 - 11:40:10 : Changing Mode to SAHARA... OK
2018-19-07 - 11:40:10 : Prepairing... OK -> [0000000D][00000000:00000034]
2018-19-07 - 11:40:10 : Sending Loader... OK
2018-19-07 - 11:40:16 : Resetting... OK
2018-19-07 - 11:40:17 : Waiting for Loader Response...OK
2018-19-07 - 11:40:17 : Memory Type: eMMC
2018-19-07 - 11:40:17 : Platform: 8953
2018-19-07 - 11:40:17 : Parameters Initialized.
2018-19-07 - 11:40:17 : Phone Booting DONE.
2018-19-07 - 11:40:17 : Retriving Partition Table... OK
2018-19-07 - 11:40:17 : Setting TIMEOUTS... OK
2018-19-07 - 11:40:17 : Load Files from: D:\mido_global_images_7.11.6_20171106.0000.00_7.0_ global_21be98f424\mido_global_images_7.11.6_201711 06.0000.00_7.0_global\images\
2018-19-07 - 11:40:22 : Flashing File 'NON-HLOS.bin' as Partition 'modem'... OK
2018-19-07 - 11:40:22 : Flashing File 'sbl1.mbn' as Partition 'sbl1'... OK
2018-19-07 - 11:40:22 : Flashing File 'sbl1.mbn' as Partition 'sbl1bak'... OK
2018-19-07 - 11:40:22 : Flashing File 'rpm.mbn' as Partition 'rpm'... OK
2018-19-07 - 11:40:22 : Flashing File 'rpm.mbn' as Partition 'rpmbak'... OK
2018-19-07 - 11:40:23 : Flashing File 'tz.mbn' as Partition 'tz'... OK
2018-19-07 - 11:40:23 : Flashing File 'tz.mbn' as Partition 'tzbak'... OK
2018-19-07 - 11:40:23 : Flashing File 'devcfg.mbn' as Partition 'devcfg'... OK
2018-19-07 - 11:40:23 : Flashing File 'devcfg.mbn' as Partition 'devcfgbak'... OK
2018-19-07 - 11:40:24 : Flashing File 'adspso.bin' as Partition 'dsp'... OK
2018-19-07 - 11:40:24 : Flashing File 'fs_image.tar.gz.mbn.img' as Partition 'fsg'... OK
2018-19-07 - 11:40:24 : Flashing File 'sec.dat' as Partition 'sec'... OK
2018-19-07 - 11:40:25 : Flashing File 'splash.img' as Partition 'splash'... OK
2018-19-07 - 11:40:25 : Flashing File 'emmc_appsboot.mbn' as Partition 'aboot'... OK
2018-19-07 - 11:40:25 : Flashing File 'emmc_appsboot.mbn' as Partition 'abootbak'... OK
2018-19-07 - 11:40:28 : Flashing File 'boot.img' as Partition 'boot'... OK
2018-19-07 - 11:40:31 : Flashing File 'recovery.img' as Partition 'recovery'... OK
2018-19-07 - 11:43:49 : Flashing File 'system.img' as Partition 'system'... OK
2018-19-07 - 11:44:02 : Flashing File 'cache.img' as Partition 'cache'... OK
2018-19-07 - 11:44:02 : Flashing File 'lksecapp.mbn' as Partition 'lksecapp'... OK
2018-19-07 - 11:44:02 : Flashing File 'lksecapp.mbn' as Partition 'lksecappbak'... OK
2018-19-07 - 11:44:02 : Flashing File 'cmnlib.mbn' as Partition 'cmnlib'... OK
2018-19-07 - 11:44:02 : Flashing File 'cmnlib.mbn' as Partition 'cmnlibbak'... OK
2018-19-07 - 11:44:03 : Flashing File 'cmnlib64.mbn' as Partition 'cmnlib64'... OK
2018-19-07 - 11:44:03 : Flashing File 'cmnlib64.mbn' as Partition 'cmnlib64bak'... OK
2018-19-07 - 11:44:03 : Flashing File 'keymaster.mbn' as Partition 'keymaster'... OK
2018-19-07 - 11:44:03 : Flashing File 'keymaster.mbn' as Partition 'keymasterbak'... OK
2018-19-07 - 11:44:48 : Flashing File 'cust.img' as Partition 'cust'... OK
2018-19-07 - 11:46:01 : Flashing File 'userdata.img' as Partition 'userdata'... OK
2018-19-07 - 11:46:02 : Flashing File 'gpt_main0.bin' as Partition 'PrimaryGPT'... OK
2018-19-07 - 11:46:02 : Flashing File 'gpt_backup0.bin' as Partition 'BackupGPT'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '40' Size: '8' Start: '14' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update last partition 49 'userdata' with actual size in Primary Header.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '40' Size: '8' Start: 'NUM_DISK_SECTORS-21.' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update last partition 49 'userdata' with actual size in Backup Header.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '48' Size: '8' Start: '1' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update Primary Header with LastUseableLBA.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '48' Size: '8' Start: 'NUM_DISK_SECTORS-1.' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update Backup Header with LastUseableLBA.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '32' Size: '8' Start: '1' Value: 'NUM_DISK_SECTORS-1.' Comment: 'Update Primary Header with BackupGPT Header Location.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '24' Size: '8' Start: 'NUM_DISK_SECTORS-1.' Value: 'NUM_DISK_SECTORS-1.' Comment: 'Update Backup Header with CurrentLBA.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '72' Size: '8' Start: 'NUM_DISK_SECTORS-1' Value: 'NUM_DISK_SECTORS-33.' Comment: 'Update Backup Header with Partition Array Location.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '88' Size: '4' Start: '1' Value: 'CRC32(2,6656)' Comment: 'Update Primary Header with CRC of Partition Array.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '88' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: 'CRC32(NUM_DISK_SECTORS-33.,6656)' Comment: 'Update Backup Header with CRC of Partition Array.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '16' Size: '4' Start: '1' Value: '0' Comment: 'Zero Out Header CRC in Primary Header.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '16' Size: '4' Start: '1' Value: 'CRC32(1,92)' Comment: 'Update Primary Header with CRC of Primary Header.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '16' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: '0' Comment: 'Zero Out Header CRC in Backup Header.'... OK
2018-19-07 - 11:46:05 : Patching DISK Offset: '16' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: 'CRC32(NUM_DISK_SECTORS-1.,92)' Comment: 'Update Backup Header with CRC of Backup Header.'... OK
2018-19-07 - 11:46:06 : Rebooting to Normal Mode... OK
2018-19-07 - 11:46:06 : Operation Time: 00:05:55
2018-19-07 - 11:51:17 : Connection terminated.
