11-18-2018, 11:38 | #1 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Reset screen lock frp on oem on... method1 : Extract stock firmware(dont forget check build number) Copy system.img sboot boot recovery to new folder Press unlock screen method1 and select system.img Wait for finish and make new system.img Copy and replace new system.img file to old new folder Make a tar file from new system.img boot sboot recovery Find a valid combination(dont forget check build) Write sboot from combination Write tar file with odin now Done Bye bye screen locks with frp on oem on Method2 : Systemui method and you can backup data after Write This file. Method3 : This method is for lz4 firmwares... Use method3 for remove firmware from encrypte and then use method1 for make reser screen lock file more info + video https://t.me/HUATEAMHELP Last edited by Hua Supporter; 01-12-2019 at 09:44. |
The Following 6 Users Say Thank You to Hua Supporter For This Useful Post: |
11-18-2018, 11:41 | #2 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | HUAWEI Method : HUAWEI ANDROID 6 AND 6 TO 7 IS SUPPORTED extract update.app with free tool insert system.img to make wait for make extract new system.img file to app again flash app file with hde flasher done |
The Following 5 Users Say Thank You to Hua Supporter For This Useful Post: |
11-21-2018, 02:39 | #3 (permalink) | |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | there could be more specific to be more clear and avoid misunderstanding just like : 1. syestem.img 2....... 3.............. Quote:
11-25-2018, 09:32 | #5 (permalink) | |
Registered User Join Date: Sep 2006 Location: usa
Member: 354431 Status: Offline Thanks Meter: 4 | Quote:
Please Best regards | |
11-25-2018, 22:52 | #9 (permalink) | |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
HuaweiUpdateExtractor repack or HDE FLASHER Extract and then make config.txt for write video https://t.me/HUATEAMHELP Last edited by Hua Supporter; 11-25-2018 at 23:11. | |
