12-24-2017, 11:58 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Mere Liye Allah He KAfi HAi
Member: 2495965 Status: Offline Sonork: 100.1646709 Thanks Meter: 218 | Xioami 4G complete Dead Recover Other All Tools Faild This Solution Work on UNLOCKED Bootloader Xiaomi Phones! With Turned Off Phone Press Volume Down and Power Button Wait Fasboot Logo Appeared Then Connect USB Cable to Phone Waiting for Device... Device Found! Reboot to EDL Done! Operation Completed Operation Time: 00:00:00 With Turned Off Phone Press Volume Down and Power Button Wait Fasboot Logo Appeared Then Connect USB Cable to Phone Waiting for Device... Device Found! Reboot to EDL Done! Operation Completed Operation Time: 00:00:00 For Android 2.x.x: 1- Turn-on the Phone Goto 'Settings > Application > Development' 2- And Check 'Usb Debugging' Then Connect Usb Cable To Phone For Android 4.x.x and Above: 1- Turn-on the Phone Goto 'General > About' Tap 7 times on MIUI version' 2- Settings in System & Device goto Additional Settings the goto Developer options 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone IMPORTANT NOTE: DON'T CONNECT MULTIPLE ANDROID DEVICE IN USB DEBUGGING MODE AT SAME TIME! Waiting For Device... OK[WinUSB] Error(2)! Stopping ADB Service... OK Operation Time: 00:00:02 With Turned Off Phone Press Volume Down and Power Button Wait Fasboot Logo Appeared Then Connect USB Cable to Phone Waiting for Device... Device Found! Reboot to EDL Done! Operation Completed Operation Time: 00:00:00 Please Note: This Solution Work on UNLOCKED Bootloader Xiaomi Phones! With Turned Off Phone Press Volume Down and Power Button Wait Fasboot Logo Appeared Then Connect USB Cable to Phone Waiting for Device... Device Found! Reboot to EDL Done! Operation Completed Operation Time: 00:00:00 Searching for Device... OK Prepairing Device on [COM9-Qualcomm HS-USB QDLoader 9008 ]... OK Waiting for Phone ACK... OK Serial Number: 0B75051C CPU ID: 007050E100000000 | Type: MSM8916 Snapdragon 410/412 SBL Ver: 00000000 OEM Key(PK): CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F Changing Mode to SAHARA... OK Prepairing... OK -> [0000000D][00000000:00000034] Sending Loader... OK Resetting... OK Waiting for Loader Response...Fail! Second Try... OK Memory Type: eMMC Platform: 8916 Parameters Initialized. Phone Booting DONE. Retriving Partition Table... OK Setting TIMEOUTS... OK Load Files from: C:\Users\Shaikh Mushahid\Desktop\dior_global_images_7.9.22_2017092 2.0000.00_4\dior_global_images_7.9.22_20170922.000 0.00_4.4_global\images\ Flashing File 'sbl1.mbn' as Partition 'sbl1'... OK Flashing File 'sbl1.mbn' as Partition 'sbl1bak'... OK Flashing File 'rpm.mbn' as Partition 'rpm'... OK Flashing File 'rpm.mbn' as Partition 'rpmbak'... OK Flashing File 'tz.mbn' as Partition 'tz'... OK Flashing File 'tz.mbn' as Partition 'tzbak'... OK Flashing File 'sdi.mbn' as Partition 'sdi'... OK Flashing File 'emmc_appsboot.mbn' as Partition 'aboot'... OK Flashing File 'emmc_appsboot.mbn' as Partition 'abootbak'... OK Flashing File 'dummy.img' as Partition 'misc'... OK Flashing File 'dummy.img' as Partition 'logo'... OK Flashing File 'NON-HLOS.bin' as Partition 'modem'... OK Flashing File 'boot.img' as Partition 'boot'... OK Flashing File 'recovery.img' as Partition 'recovery'... OK Flashing File 'system.img' as Partition 'system'... OK Flashing File 'cache.img' as Partition 'cache'... OK Flashing File 'userdata.img' as Partition 'userdata'... OK Flashing File 'gpt_main0.bin' as Partition 'PrimaryGPT'... OK Flashing File 'gpt_backup0.bin' as Partition 'BackupGPT'... OK Patching DISK Offset: '40' Size: '8' Start: '9' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update last partition 29 'userdata' with actual size in Primary Header.'... OK Patching DISK Offset: '40' Size: '8' Start: 'NUM_DISK_SECTORS-26.' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update last partition 29 'userdata' with actual size in Backup Header.'... OK Patching DISK Offset: '48' Size: '8' Start: '1' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update Primary Header with LastUseableLBA.'... OK Patching DISK Offset: '48' Size: '8' Start: 'NUM_DISK_SECTORS-1.' Value: 'NUM_DISK_SECTORS-34.' Comment: 'Update Backup Header with LastUseableLBA.'... OK Patching DISK Offset: '32' Size: '8' Start: '1' Value: 'NUM_DISK_SECTORS-1.' Comment: 'Update Primary Header with BackupGPT Header Location.'... OK Patching DISK Offset: '24' Size: '8' Start: 'NUM_DISK_SECTORS-1.' Value: 'NUM_DISK_SECTORS-1.' Comment: 'Update Backup Header with CurrentLBA.'... OK Patching DISK Offset: '72' Size: '8' Start: 'NUM_DISK_SECTORS-1' Value: 'NUM_DISK_SECTORS-33.' Comment: 'Update Backup Header with Partition Array Location.'... OK Patching DISK Offset: '88' Size: '4' Start: '1' Value: 'CRC32(2,4096)' Comment: 'Update Primary Header with CRC of Partition Array.'... OK Patching DISK Offset: '88' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: 'CRC32(NUM_DISK_SECTORS-33.,4096)' Comment: 'Update Backup Header with CRC of Partition Array.'... OK Patching DISK Offset: '16' Size: '4' Start: '1' Value: '0' Comment: 'Zero Out Header CRC in Primary Header.'... OK Patching DISK Offset: '16' Size: '4' Start: '1' Value: 'CRC32(1,92)' Comment: 'Update Primary Header with CRC of Primary Header.'... OK Patching DISK Offset: '16' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: '0' Comment: 'Zero Out Header CRC in Backup Header.'... OK Patching DISK Offset: '16' Size: '4' Start: 'NUM_DISK_SECTORS-1.' Value: 'CRC32(NUM_DISK_SECTORS-1.,92)' Comment: 'Update Backup Header with CRC of Backup Header.'... OK Rebooting to Normal Mode... OK Operation Time: 00:05:11 |
The Following 3 Users Say Thank You to SMflasher For This Useful Post: |
