Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-19-2016, 21:25   #1 (permalink)
Member: 717129
Thanks Meter: 11
Advice needed for iPhone 6 touch ID problem
Dear All,
I have a iPhone 6 with a touch id problem.
Everything is original i.e. button flex ( I have tried a new long home button ribbon which runs from the plug to the button flex )
The phone allows you to go into the enter finger print part but once you're in it the button it's self does not reconise a finger has been placed on top of it.
I also do not get the "oops" message if I press the button during the finger print reading.
Any ideas what components to check to determine why the finger print part of the button is not registering when a finger is placed on it?
Thanks for any advice
Oliver
Old 10-21-2016, 16:55   #2 (permalink)
Member: 2565303
I have alse the same problem with the original home button and I tried almost everything and it is not working.. i am also interested in a solution is there anyone that can help me??
Old 10-21-2016, 17:26   #3 (permalink)
Member: 2565303
Did you changed your LCD??
Old 07-29-2017, 12:19   #4 (permalink)
Member: 162876
Thanks Meter: 7
I have also same problem with a 6 plus. Problem was the bad quality of flex cable between home/ touch sensor and mainboard. After a little resoldering/ cleaning the connectors, all is ok!
Old 07-31-2017, 14:06   #5 (permalink)
Member: 1849865
Thanks Meter: 5
Look for any micro tear on the home button flex.. also it might be your long flex cable, the one that runs in back of the LCD which I've seen go bad and just try a different one
Sent from my iPad using Tapatalk
Old 08-01-2017, 09:37   #6 (permalink)
Member: 2624117
Thanks Meter: 2
Check the place around your home button connector on the board. It is also possible that u damaged a cap around the connector.
Page generated in 0.44906 seconds with 8 queries
