09-04-2018, 03:25 | #4 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | Error 403 means that the server has denied you access. So it depends on the reason why the server denied your access you have to specify the “app/webite” that is giving you such an error. |
09-04-2018, 03:28 | #5 (permalink) |
Member: 2861866 Status: Offline Thanks Meter: 71 | The issue is the nand needs to be formatted. Removal of the nand with navipro machine is required for this repair. Microsoldering skills needed to. Unless you have some personal attachment to this phone. |
09-04-2018, 07:28 | #6 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | 4013 Error in PCie Nand devices such as 6s/6s+/7/7+/5se is not always due to Nand. 4013 Error is also caused due to short in Baseband section. If you are unable to repair it even after changing the Nand then you need to check the baseband. Hope that helps. |
