Fix iPhone 6S Auto Shutdown When it Still Has Battery? Some users reported that their iPhone 6S or iPhone 6S Plus shut off randomly even it still had 40% or more battery remaining. Apple admitted it’s a bug the battery status did not update. After a series of investigation, they came to a conclusion that the time zone or clock setting seemed to be the culprit,but Many users still think it must because they were updated iOS 10. http://www.3u.com//upload/20161115/1...9518076657.png So when you’re unfortunately suffering from this issue, first is to reboot your device and go to Settings > General > Time and Date to set it as auto-setting mode. If the problem still exists, try following tips before sending in Apple for repair. 1. DFU Restore A “DFU Restore” (DFU is short for Device Firmware Update) is an even deeper restore mode than the recovery mode according to Apple’s description on their website. You can DFU restore your device with following instructions: * Plug your iPhone 6s/6s Plus into a computer and open iTunes or 3uTools. * Press and hold the Power Button and Home Button together for 8 seconds. * After 8 seconds, release the Power Button but continue to hold the Home Button until iTunes says “iTunes has detected an iPhone in recovery mode.” * Let go of the Home Button. Your iPhone 6S will go black completely if you’ve successfully entered DFU mode. If it’s not, try again from the beginning. * Restore your iPhone 6S using iTunes. http://www.3u.com//upload/20161115/1...4857022630.jpg 2.Using 3uTools How to enter DFU mode: Firstly hold the Home button, and then the Power button. Continue holding them for about 4 seconds after the screenbecome blank, and then release the Power button. Keep holding the Home button till 3uTools detects an iOS device in DFU mode. How to exit the DFU mode: Hold “Home+Power” till the Apple logo comes out on the screen, and then the device can exit the DFU mode. http://www.3u.com//upload/20170207/1...3022048693.png 3. Battery Calibration Your iPhone 6S may need a battery calibration, learn how to calibrate an iPhone 6S battery here: * Run your iPhone 6S battery down to 0% and auto power off. * Charge your device till it reaches 100%, do not unplug or use it during the charging. * Leave your iPhone 6S on charge for one more hour although it has reached 100%. * Use your device as normal to drain the battery till zero, do not charge it during this usage. * Charge your iPhone 6S to 100% again and charge another hour to make sure it’s fully and completely charged. * Now your iPhone 6S’s battery is calibrated. http://www.3u.com//upload/20161115/1...2991018187.png If one of above tips you work, possibly it’s a faulty battery, please consult your local Apple Service for a replacement. Apple will not charge you anything to replace a battery if your iPhone 6S is still under AppleCare+. http://www.3u.com//upload/20161115/1...3404046219.jpg However, if you’re not covered with the warranty or AppleCare+, at least $79 will be charged to get your iPhone 6S battery replaced. Compared with that, to buy an iPhone 6S battery at an approximate cost of $40 and have it replaced by someone else or by yourself would be cheaper. Please note that you run your own risk and the warranty will be voided if you’re going to replace your iPhone 6S battery by third parties. As you may need, here is a tutorial guide about Whether Your iPhone 6s Qualifies for Apple's Free Battery Replacement Program? Source: 3uTools |
