08-03-2017, 07:07 | #1 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2737783 Status: Offline Thanks Meter: 39 | How to Upgrade iDevice Via 3uTools Pro Flash? Preparations: * Download and install the latest 3uTools on your computer. Make sure you have installed the latest iTunes on PC, if not, install it via 3uTools. * Backup your iDevice using 3uTools so as to stop data from losing. * Set iDevice into DFU mode. Hold HOME button, then hold power button till the screen becomes blank; release the POWER button after a few seconds, but keep holding the HOME button for about 10 seconds. Step1: Launch 3uTools, connect your iDevice to PC using the USB cable. Make sure iDevice is in DFU mode. Step2: Keep your iDevice in DFU mode. Click Flash & JB -> Pro Flash -> Import Firmware. Now you need to import the particular firmware you have download previously. Step3: After it is imported, click Flash. 3uTools will send you reminder that currently the firmware version you selected doesn’t support” Reserve baseband while flashing”. Do you want to continue this operation? Click Yes. Step4: Wait patiently till the flash process is finished, and your iDevice will restart automatically after flash. Thanks for visiting. For more latest updates or supports, follow us on Facebook or Twitter. |
The Following 2 Users Say Thank You to TGB For This Useful Post: |
