06-05-2015, 16:11 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 562132 Status: Offline Thanks Meter: 86 | i phone 6 auto restart after open- after updat of itunes also same but after try updat at mfc then problem solved is that real mfc flasher can fix what itunes can,t fix!???? imazing [info] Starting operation ... [info] Using LATEST available IPSW. [info] NOTE: Updated version data. [info] Found device in Normal mode [info] MFC Identified device as iPhone7,2 [info] Latest firmware is iPhone7,2_8.3_12F70_Restore.ipsw [info] Downloading latest firmware (http://appldnld.apple.com/ios8.3/058...0_Restore.ipsw) [info] Waiting for program to exit ... [clea] [info] This update adds new functionality to your MFC Dongle. Now the dongle will automatically adjust the birghtness before starting the unlock process. This will save battery and also will make the sensor detection more reliable than before. You need to connect the sensor and go to the emergency calling screen before connecting MFC Dongle Do not connect the sensor on the brightness display icon ! [clea] [info] Starting operation ... [info] Using LATEST available IPSW. [info] NOTE: using cached version data [info] Found device in Normal mode [info] MFC Identified device as iPhone7,2 [info] Latest firmware is iPhone7,2_8.3_12F70_Restore.ipsw [info] Verifying 'iDeviceTools//iPhone7,2_8.3_12F70_Restore.ipsw'... [info] Checksum matches. [info] Extracting BuildManifest from IPSW [data] Product Version: 8.3 [data] Product Build: 12F70 Major: 12 [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Found ECID 7359684172368314 [info] Getting ApNonce in normal mode... [data] 3531BC9FE5DFC393F240D436FABF24E9D36C797C [info] Trying to fetch new SHSH blob [info] Getting SepNonce in normal mode... [data] 40C2CF6134B992EE47057A3E2E3E7C070CA56278 [info] Received SHSH blobs [info] Extracting filesystem from ipsw [info] Entering recovery mode... [info] device serial number is F4RP9DQLG5MT [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n61.RELEASE.im4p... [info] Sending iBEC (644617 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-2261.20.20 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@2x~iphone.t7000.im4p... [info] Sending AppleLogo (12139 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-14818-073.dmg... [info] Sending RestoreRamDisk (17221117 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n61ap.im4p... [info] Sending RestoreDeviceTree (168119 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.n61... [info] Sending RestoreKernelCache (9346115 bytes)... [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 13 [info] Device has successfully entered restore mode [info] Hardware Information: [info] BoardID: 6 [info] ChipID: 28672 [info] UniqueChipID: 7359684172368314 [info] ProductionMode: true [info] About to send NORData... [info] Found firmware path Firmware/all_flash/all_flash.n61ap.production [info] Getting firmware manifest Firmware/all_flash/all_flash.n61ap.production/manifest [info] Extracting LLB.n61.RELEASE.im4p... [info] Extracting DeviceTree.n61ap.im4p... [info] Extracting applelogo@2x~iphone.t7000.im4p... [info] Extracting batterycharging0@2x~iphone.t7000.im4p... [info] Extracting batterycharging1@2x~iphone.t7000.im4p... [info] Extracting batteryfull@2x~iphone.t7000.im4p... [info] Extracting batterylow0@2x~iphone.t7000.im4p... [info] Extracting batterylow1@2x~iphone.t7000.im4p... [info] Extracting glyphplugin@1334~iphone-lightning.t7000.im4p... [info] Extracting iBoot.n61.RELEASE.im4p... [info] Extracting recoverymode@1334~iphone-lightning.t7000.im4p... [info] Extracting sep-firmware.n61.RELEASE.im4p... [info] Sending NORData now... [done] sending NORData [info] About to send RootTicket... [info] Sending RootTicket now... [done] sending RootTicket [info] Partition NAND device (28) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Waiting for NAND (29) [info] Checking filesystems (16) [info] Unknown operation (51) [info] Waiting for NAND (29) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Restoring image (14) [info] Checking filesystems (16) [info] About to send KernelCache... [info] Extracting kernelcache.release.n61... [info] Sending KernelCache now... [done] sending KernelCache [info] Loading kernelcache (27) [info] Unknown operation (18) [info] Unknown operation (46) [info] Flashing NOR (19) [info] About to send BasebandData... [warn] WARNING: size mismatch when parsing MBN file. [info] Sending BasebandData now... [done] sending BasebandData [info] Flashing NOR (19) [info] Updating Baseband in progress... [info] About to send BasebandData... [warn] WARNING: size mismatch when parsing MBN file. [info] Sending BasebandData now... [done] sending BasebandData [info] Updating Baseband in progress... [info] About to send BasebandData... [warn] WARNING: size mismatch when parsing MBN file. [info] Sending BasebandData now... [done] sending BasebandData [info] Flashing NOR (19) [info] Updating Baseband in progress... [info] About to send BasebandData... [warn] WARNING: size mismatch when parsing MBN file. [info] Sending BasebandData now... [done] sending BasebandData [info] Flashing NOR (19) [done] Updating Baseband completed. [info] Mounting filesystems (17) [info] Unknown operation (25) [info] Unknown operation (51) [info] Waiting for NAND (29) [info] Got status message [info] Status: Restore Finished [info] Cleaning up... [done] DONE [done] Operation finished! now mobile working fine without lose user data thanks team |
