05-01-2018, 10:02 | #1 (permalink) |
Junior Member Join Date: May 2017
Member: 2718943 Status: Offline Thanks Meter: 3 | i phone 6s battery discharging fast with in 4 hour..i change battery and u4500(u2) no water damage..any body can help thank u... |
04-25-2019, 15:42 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | Quote:
bro u get that problem solved? | |
08-19-2019, 16:21 | #5 (permalink) |
Insane Poster Join Date: Jan 2014 Location: pt
Member: 2103265 Status: Offline Thanks Meter: 59 | Got the same issue, Already tested with 3 different Batteries - no luck. Instant Consumption of 220~250 mAh with screen on, on full battery, no background services. Instant Consumption 140~170 mAh all the same BUT with screen OFF. Full charge of battery goes away in 4/5 Hrs, with the phone in stand by. If using phone, its drains around 1% each 2 minutes. Compass works fine, Wifi ok. Camera OK. Original LCD and the rest of extra components tested, all new and original, the phone was damaged , cracked screen and main camera. In airplane mode - battery drains the same. What should I test next? |
09-01-2019, 19:27 | #6 (permalink) |
Insane Poster Join Date: Jan 2017
Member: 2669015 Status: Offline Sonork: jude101 Thanks Meter: 7 | Remove the battery from the iphone and plug charger maybe it will show Apple If the iphone show Apple without no battery that means is the battery And if it does not show that means is the u2 ic |
09-03-2019, 14:27 | #7 (permalink) |
Freak Poster Join Date: May 2016 Location: Unlock world Age: 35
Member: 2578723 Status: Offline Thanks Meter: 15 | Iphone battery drain Common problem is failure of U2 IC chip. To test it you can use thermal camera or freezer spray. When you spray freezer, let it cool down and connect AC voltage 4.2V on and you will see U2 highlights itself. Hope it helps! |
09-12-2019, 11:05 | #8 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | There are have some reasons for iPhone battery discharging fast below: 1. Battery cable poorly connected with the connector 2. Logic board electricity leakage 3. Excessive running apps |
10-16-2019, 11:41 | #11 (permalink) | |
Junior Member Join Date: Jan 2013 Location: India
Member: 1862559 Status: Offline Thanks Meter: 4 | Quote:
