i phone6 restored error.......... |
if you get error 3004 Try this 5 Step bro_________________ Solution No.1: Restart your modem Many users solved the issue within seconds, by simply restarting the modem. In most cases, the problem is the network connectivity, which is why this simple step this can fix the problem. Turn off your modem, and after 10-15 seconds, turn it on again. Connect your iPhone to your computer via USB cable, and try to update again. Solution No.2: Restart your computer Did you restarted your computer lately? If the answer is no, this solution may do the trick. Close iTunes, and restart. Turn your computer back on, and try to update or restore. Solution No.3: Firewall Firewall sometimes may be the problem. Allow iTunes in the Firewall options. Solution No.4: Update iTunes to the latest version All 5 ways to fix iPhone error 3004 are simple, including this one. Open the iTunes software and follow these steps: If you are using Mac, from the menu, select iTunes, and Check for Updates; If you are using Windows, from the menu choose Help, and then Check for Updates. Solution No.5: Update or turn off your security software Error 3004 may be connected with your security software. First, try to update it if you don’t have the latest version. If that does not help, simply turn it off, and restore or update your device. |
And Check Internet Connetion _______________ |
no sir,in way this did not solve this............ |
No internet connection during the firmware restore |
sir internet connection is ok............. |
